Patch Management SMB share question
  • July 23, 2023
  • 0 replies
  • 17 views
I do have a question regarding patch management and a smb share. We are using Jamf on premise. and we do have a DP that is in the DMZ and is using a smb share and https.
So if I configure a computer outside of the internal network all policies gets installed. But if for example a patch should be installed I often get in the logs an error. Trying to mount the smb share... tried for 3 times and always fails.
Shouldn't that also work? I mean of course without a vpn connection he cannot mount the smb share but then he should be dl it from the https source.
Or is the patch management still broken I have the latest 10.48.1 server version installed
