Nessus Agent EA - What is the agent linked to?
  • July 24, 2023
  • 68 views
mvu
Forum|alt.badge.img+21
Hi everyone,
Combing over articles, including this one: http://www.cainehorr.com/jamf-workflow-for-tenable-nessus-agent/.
Is anyone using an extension attribute that tells you what host the Nessus Agent is currently linked to? This way we can see if it's incorrectly linked to the wrong host in the EA, then send a policy to re-link the Macs to the right host.
Currently using the EAs below ok:
• Nessus Agent Installation Status
• Nessus Agent Service Status
• Nessus Agent version
Thank you!
Best answer by jtrant
We're in the cloud so I have no way of verifying this works, but it might help:
if [ -e /Library/NessusAgent/run/sbin/nessus-service ]; then nessusHost=$( /Library/NessusAgent/run/sbin/nessuscli agent status | grep "Connected to" | awk '{print $5}' ) echo "<result>$nessusHost</result>" else echo "<result>Not Installed</result>" fi
I hate blank EAs in Jamf inventory so tend to always make them conditional, but you don't need to do that if you don't want to.
  • July 25, 2023
mvu
  • July 25, 2023
@jtrant That worked! Very cool. It worked exactly what we needed. Thanks a lot!!! Will test some more but looks good.
