What did you build in your Adobe package? On the Mac you're testing with, are there any Adobe products previously installed? Like Adobe Creative Cloud?
This package has Photoshop and Illustrator and no, the Mac has no other Adobe products installed on it.
Ran into something similar on my end.
Did some research and came across this KB article from Adobe:
https://helpx.adobe.com/enterprise/kb/deploy-packages-using-jamf-pro.html
I uploaded my .pkg via Jamf Admin, applied it to a policy and it worked.
Hope that works for you!
Are you trying to deploy specific Adobe apps or are you trying to deploy the Creative Cloud app launcher where users can make their own choices on which to deploy?
I have to say, when I started with Jamf about 9 months ago the app packages downloaded from the Adobe admin console worked just fine and they'd install no issue. Somewhere around 2 months ago those packages that previously worked simply stopped and would get nothing but errors such as you're describing. We originally used the MacOS (Universal) platform when downloading the installer however neither that, nor MacOS (Intel) or MacOS (Apple Silicon) would work on any of the devices.
Around that same time we discovered that Jamf managed apps were now allowed to be advertised in Self Service which was a big sticking point for us. We rolled over to the Jamf managed versions of all the apps and those have been working for us quite well.
I know this is a redirection more than a solution, but if that's something you're considering at least it'll give you an alternative path to deploying the software.
It is specific apps, Photoshop and Illustrator. I am happy to report that @sonance suggestion of making the package in Jamf Admin, worked. What's funny is my experience seems to be the opposite of yours. My experience has more or less been this...
- Made and downloaded an Adobe package and set up a SMB distribution point. Worked with another tech here who does WDS deployments and we couldn't get it to work.
- Tried making a script to make a local folder, mount the package on our SMB share, copy it to the local folder and then unmount. Kept getting issues on the mounting, even though the path was correct because I could use that same file path in Terminal and open it.
- Went to Computers > Mac Apps> Jamf App Catalog and downloaded the Illustrator and Photoshop applications. They pushed out to my test mac just fine and installed. The issue here was the credential I was using to log in (via Google SSO) came back as not having full access and said I had a 7 day trial.
Comapre all this to the fact that I could make the package in Adobe CC Admin, download it, install it directly onto my test Mac and it all works fine. Last year before we used Jamf to manage the Macs, they were essentially free agents out in the High School. We had an admin account on there and some of our firewall and remote access tools but that was it. And those tools, like the Adobe products we're installed one by one by one. As it was then, it is true now; directly installing adobe via its package right onto the Mac, eliminating Jamf in this process, works.
It wasn't until Sonace suggested Jamf Admin that I had success. Creating the package through that and then assigning that package to a policy in Jamf Pro pushed down Adobe CC and when installed, it also installed Photopshop and Illustrator and logging in with my Adobe cred, it recognized it as an education account and I had full app access, no trial.
For me, this is the stupidest thing ever, i had to re zip the PKG file instead of letting jamf do it... i dont have access to jamfadmin as we are cloud hosted. But from this thread, mid way thru, you can see that someone said that just zipping the pkg file worked and lo and behold it did.
https://community.jamf.com/t5/jamf-pro/proper-way-to-install-adobe-creative-cloud-package/m-p/234092
simply take the install.pkg file out of the zip file that you get from adobe. Then rezip just that file, then upload to packages. works.
I was also facing the same issue. Please take a look at the below error message from Jamf.
Installation failed. The installer reported installer: Package name is Adobe Cloud Universal_Oct_2023
installer: Installing at base path / installer: The install failed. (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. An error occurred while running scripts from the package “Adobe Cloud Universal_Oct_2023_Install.pkg”.)STEP 3 of 4]fSTEP 4 of 4]
I also tried uploading the package via Jamf Admin, but the result remains the same.
Does anyone has any advice on Adobe Cloud app deployment? Thanks
