iKEv2 in JAMF pro
  • August 17, 2023
  • 133 views
Hey, I noticed that due to profile configuration I don't have ikev2 vpn profile.. is it normal that I don't see it?
Best answer by matteo_bolognin
You should be able to display the payload switching the Config Profile to User-Level in Option > General > Level:
matteo_bolognin
  • August 18, 2023
oh yes indeed - thank you! I have another question because I'm migrating from jamfcloud to pro and when importing my profile from ikev2, if I change to user level and then I'll save it .. the certificate info is removed from the config and if I assign even such a profile to the user, I have n / in pending and. Do you have an idea what the problem could be?
matteo_bolognin
I honestly wouldn't go the import way but rather create a new profile from scratch, uploading certs in the dedicated payload.
Less than ideal but there's some caveats when uploading an entire cert as an xml blob (when uploading non-signed profiles).
