Disable Firefox network.http.http3.enabled
  • August 22, 2023
  • 9 replies
  • 197 views
Hi Team,
How do i disable Firefox's diable HTTP/3 (network.http.http3.enabled).  I have to create a configuration profile and push it via JAMF to all of the end users.
Can someone give me an XML template for this? i couldn't find it anywhere
AntMac
  • August 23, 2023
Hi
That setting is not anywhere in the regular policy plist settings example file that Mozilla publishes:
policy-templates/mac/org.mozilla.firefox.plist at master · mozilla/policy-templates · GitHub
However, they have some additional references/examples to supported payloads which includes network prefix payloads.
GitHub - mozilla/policy-templates: Policy Templates for Firefox
  • November 9, 2023
@hari_premasiri were you able to get this setting configured?
  • December 22, 2023
@karengarner Did you managed to ever get this working?  Looking for same solution...
shrisivakumaran
Hi, Anyone find the way to disable Quic protocol in Firefox?
  • January 7, 2024
@karengarner  & @shrisivakumaran
Sorry for the late response,
Unfortunately, I have looked through Mozilla's documentation on plist and have not been able to find anything to restrict this setting available yet.
https://github.com/mozilla/policy-templates/blob/master/mac/org.mozilla.firefox.plist
This might have to be a feature request on Mozilla's side to allow control over this setting.
shrisivakumaran
Thanks, I got the solution from Mozilla Support forum page. now able to control it
  • February 19, 2024
Would you be willing to share how that you are controlling this?
shrisivakumaran
@timbyler1890 using below plist to disable quic protocol in Firefox.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>EnterprisePoliciesEnabled</key> <true/> <key>Preferences</key> <dict> <key>network.http.http3.enable_0rtt</key> <dict> <key>Value</key> <false/> <key>Status</key> <string>locked</string> </dict> <key>network.http.http3.enable</key> <dict> <key>Value</key> <false/> <key>Status</key> <string>locked</string> </dict> </dict> </dict> </plist>
  • February 20, 2024
Thanks a lot for that info.
That is what I was going to try but that should save me a lot of time.
