Setting up a jamfpro test enviroment
  • August 28, 2023
  • 8 replies
  • 179 views
Dperk
Does anyone have any guides within the past 3 years for getting the dev environment setup for jamf pro? Everything i find online is from 2016-18 and rather outdated. I want to test the LAPS but dont want to enable it in prod incase pulling the password doesnt work.
Best answer by jamf-42
Ask jamf. You can get a test cloud instance
  • August 28, 2023
I use test workstations in prod and always use to test any changes before doing the next step
Alpha = the test workstations in IT only.  If no issues, goes to Beta stage
Beta = selected few people that are somewhat compute savvy.  If no issues from users, goes to Global
Global = goes to requires workstations / MacBooks
jamf-42
  • August 28, 2023
  • August 29, 2023
It would be awesome if Jamf provided a dummy database as they do with the training classes. It's quite a lot of work to populate an empty database with test devices.
  • August 29, 2023
You can use the Jamf Migration tool to import stuff from your prod environment over to your test. It is really easy! https://github.com/jamf/JamfMigrator
  • August 29, 2023
We had faith in this particular feature (apart from that we've actually forgot the static admin password). So we enabled it in prod. We have a pretty large environment and this works like a charm for us. But yes, if we had a need for these passwords more often than very rarely, the current state where you need to query the API for it would be pretty cumbersome.
Dperk
  • August 30, 2023
Someone last week made a neat little GUI to get the passwords that i very eagery want to try out. Hopefully i can get it working with the test, but im glad to hear that its working good in prod. Did you do all the changes directly from the API?
Dperk
  • August 30, 2023
Thank, ill deff give that a go once we get the test environment, i reached out to our rep and they got me in contact with the team that can spin up the instance.
Dperk
  • August 30, 2023
Marking this the solution, because they are able to get me the instance without any hassle.
