Package Installation failed
  • August 31, 2023
  • 0 replies
  • 29 views
seem to be having issues deploying 2 packages out of 3 edge seems to deploy ok and will install but i am having issues installing Eset and Datto i am getting the following errors.
nstallation failed. The installer reported: installer: Package name is ESET Endpoint Solutions
installer: Installing at base path / installer: The install failed. (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. An error occurred while running scripts from the package “epi_mac_live_installer (1).pkg”.)
I have downloaded the pkg again and install them on my own machine ok
