Only Update Apps Over WIFI
  • September 4, 2023
  • 0 replies
  • 70 views
We have several hundred field workers with iPhones and iPads. Our mobile apps are set to auto update when updates are available. When in the field, and away from WIFI, often times, the app updates will take a considerable amount of time to finish, during which the app is unavailable to use.
Is it possible to have app updates only happen when connected to WIFI? That way, updates would never happen in the field and disrupt the use of certain apps. I would like to retain the ability to deploy and install new apps even when the people are away from WIFI. So if it is possible to only UPDATE apps over WIFI, would that prevent them from RECEIVING and installing new apps in the field?
Thanks,
Rob
