Hello All,
While checking the manual below, We are trying to assign users belonging to the Active Directory security user group to specific sites.
* We use the Jamf Infrastructure Manager with LDAP proxy set in our Jamf Cloud instance.
http://docs.jamf.com/10.8.0/jamf-pro/administrator-guide/User-Initiated_Enrollment_Settings.html
>Configuring the User-Initiated Enrollment Settings
In the following workflow, the Active Directory security user group is not displayed in Access pane of User-Initiated Enrollment.
Is there any information?
<Workflow>
1.Create AD security user group
2.Add the user to AD security user group.
3.Configuring the User-Initiated Enrollment Settings
Settings>Global Management>User-Initiated Enrollment>Edit>Access pane
4.The Active Directory security user group is not displayed.
