encrypt wifi
  • September 20, 2023
  • 13 views
Is there a way to configure a profile to keep the wifi password encrypted in ios 16 and higher?   As of now, if you press and hold the "encrypted" wifi password in settings, the actual password shows up.
1 reply
You can create a configuration profile to push out the WiFi payload configured and it will remove the password visibility.
