How to prevent users from signing in downloading from App Store.
  • September 20, 2023
  • 4 replies
  • 47 views
Hello, I am looking for a way for users not to sign in to the App store and download any apps. Is that possible via Jamf?
Ashok_A
  • September 21, 2023
@Mouthbaten_1911 You can use Restriction Payload from the Configuration Profile. Under Applications, you can deselect "Allow App Store Adoption".
I have tried that, and it still allows to download and install apps from the app store.
Ashok_A
Ok, I have missed to add the below.
Go to the "Applications" tab under the "Restrictions" payload in a Configuration Profile. Check "Restrict which apps are allowed to launch" and then add "/Applications/App Store.app" (without quotes) under "Disallow Folders".
Check if that works. Thank you!
agungsujiwo
  • November 2, 2024
@Mouthbaten_1911
You can activate this feature, then when you apply the appstore will not appear / hidden / disappear from the ipad screen, and when searched will not be found.
configuration profile > profile > option > restrictions > apps > installing apps using appstore
