Can't block Sonoma
  • September 26, 2023
  • 78 replies
  • 611 views
AVmcclint
Forum|alt.badge.img+21
I have deployed a Config Profile with the following code to block Software Update from seeing the major OS releases (Sonoma) for 90 days with com.apple.applicationaccess for the domain:
<plist> <dict> <key>enforcedSoftwareUpdateMajorOSDeferredInstallDelay</key> <integer>90</integer> <key>forceDelayedMajorSoftwareUpdates</key> <true/> </dict> </plist>
Sonoma was released by Apple 25 minutes ago and already I see Macs that are displaying Sonoma as an available update!
 I have verified that the Config Profile has been installed on these Macs for many weeks. Every single time there's a new Major OS release, it's like trying to hit a moving target. How on earth are we supposed to block Major OS releases?
The same configuration is working fine for me. Is Sonoma actually appearing in Software Update for the Macs reporting it as an available update?
AVmcclint
Right now,I can only confirm what Jamf reports and what the softwareupdate -l command reports.
jamf-42
block the pref pane in System Settings, block softwareupdate binary.. and cross fingers.. (its a major update so correct restrictions config profile should do it)
jamf-42
if software update bin is reporting available then the config profile is wrong or not deployed? I use the full legacy restrictions profile (yes I know) but.. it works.. just tested.. (for my own sanity.. considering recent events) 😎
@AVmcclint Excuse my ignorance, how are you building that Configuration Profile? Is it a specific tool you are using? or directly in Jamf?
sdagley
@AVmcclint Make sure you don't have another Configuration Profile that sets the delay key. If you have more than one such profile Apple says the results is ¯\\_(ツ)_/¯
Also note that if you do set a deferral that only means the user can't initiate the update. If you send an MDM command to update to latest available version you will now get macOS Sonoma 14 on hardware that supports it.
Is restriction not working?
Also, note if you use erase install to install or update it will now pull macOS Sonoma as well unless a different OS is specified with options.
AJPinto
  • September 27, 2023
Software Update is under System Settings > General > Software Update as of Ventura. You cant block anything under General. The descriptions on the Preference Pane Configuration Profiles have not been updated by JAMF, many of those payloads only apply to Monterey and below.
AJPinto
Have you tried to install the OS update and see what the install.log reports? If the deferral is working correctly, you will see comments saying the OS updates are deferred until XYZ date if the device tries to initiate an update. Id also check for duplicate configuration profiles trying to manage OS updates, as that makes things a mess.
Starting to see this as well, the config profile was deployed to an M2 prior to release for deferring the major OS update for 90 days..
They still were able to update to Sonoma from System Settings without admin rights.
Previous OS: 13.5.2
Hardware: M2
Account Type: Standard
This is for multiple users, however, it's not consistent. I see the block on my Mac(M1) and test Mac(Intel)..
So it's something weird going on, that I'm just now having to look into
It's this kind of stuff that makes me want to pull my hair out. We are restricting the `Install macOS Sonoma.app` and are deferring major updates, so far no one has updated, but if standard users are able to via softwareupdate prior to the 90 day major restriction we have in place then....what in the world Apple?
So after doing some testing/research.. It seems that the deferral for Major Updates does not prevent the Sonoma upgrade from being seen, if there is a Minor Update for the current OS.
Once you apply the latest minor updates, the config profile for the Major Update is now working in regards to preventing OS Sonoma as an available upgrade option.
I'm not sure if this a Jamf issue or Apple bug.. However, this is my findings from testing. And I'm sure we can replicate it. At this point, we would have to set the deferral for both minor/major versions for devices that's not on the latest of their current OS
mvu
We're seeing Sonoma in System Settings as well. I deferred it using the 90-day Major Update configuration profile. It's hit or miss. Sometimes shows up, and sometimes it doesn't.
Do you have a minor OS update available? If so, apply the minor update, and see if it defers the major update afterwards
jamf-42
as mentioned.. we have this setting, along with a block for access to Software Update in system settings.. and nobody can update.. if you look at the logs for /var/log/install.log you can see the deferral and dates..
if you run softwareupdate -l  it returns 'no updates available'
Our devices are on macOS 13.4.1 to 13.5.2
Yes, but it appears that if you have the "Set different delay for minor software updates" checked to keep up with security updates that it is allowing Sonoma to show up. Just discovered this with a computer running 13.3. Testing JustDeWon's theory now by updating to 13.6.
mvu
Yes, on 13.6 on different Macs. Checking conflicting config profiles.
jamf-42
hindsight on this means when there is a major update, we lock it all off.. mixing point updates and major always goes wonky with the current framework.
due to Apples user centric update process, we always have a few stragglers.. but less than 10% of the global estate...
macOS 14 will fix all this.. 🤔 🤔 maybe. hopefully..
  • September 28, 2023
If you use "Restricted Software" tab and configure as process name:  Install macOS Sonoma.app
And check the box; Restrict exact process name, Delete application and kill process
That should take care to avoid download or install sonoma app untill you exclude the endpoint the scope.
mvu
Customers can still see it in System Settings/General/Software Update. Unless you use a configuration profile to defer.
we are using a config profile to defer major updates for 90 days, we just had two users, including myself, where Sonoma installed automatically on it's own.
There is definitely something amiss here
mvu
Same here. Do you happen to have 2 or more Restriction configuration profiles set up?
we have two older Restriction config profiles that were setup incorrectly by a previous admin quite some time ago.
We excluded all of our devices and new devices from these two config profiles and now have just the one.
It didnt give us any issues during ventura, but i'm wondering if this could somehow be causing issues  
in our main config profile, we had everything here checked except Allow installation of macOS beta Releases until this morning. I'm also wondering if that could have caused any issues
@mvu user can see that but that will not install. If they download that will cancel and remove .app from /Application folder. So, it is safe to use that Restriction. I used to use that till Ventura. Don't know anything changed for Sonoma or not. But pretty sure that works. It is already implemented in our environment.
