Change Mobile Device App Distribution Method
  • October 6, 2023
  • 24 views
I apologize if this has been asked and answered or documented somewhere, but I've looked and can't really find my answer.
I'm looking to change the distribution method for an app from Install Automatically to Make Available In Self Service. I know how to do that, but my question is what will this do to devices that already have the app installed? Will the app be pulled and require them to download it, or will it remain on device?
-Matt
Best answer by mSkripps
Nevermind! I just tested this with an app we no longer use and found that changing the distribution method does not pull the app from the device. :)
1 reply
  • October 6, 2023
