Grant Secure Token to end user
  • October 11, 2023
  • 5 replies
  • 376 views
ajanicke
We seem to be running into an issue with Secure Tokens. Searching has made me realize this is something most people are having difficulty with but it's usually with the Admin account not having a token but ours is sometimes the other way around.
Long story short a second admin account that was added during the enrollment stage was getting the token then other users logging into the device would not get a token, now really showing itself with updates and the users getting a "You need to be an owner" error.
So I created a script to run from Self Service that just prompts the user for their password then runs the command and passes the credentials of the Admin with the secure token. However, it always errors out saying the users password is incorrect but when I test and run the same thing from the terminal on the test device it works fine. Is there something I'm missing here? Does apple do something to restrict this kind of access from a script?
#!/bin/bash # Prompt the user for their username and password using AppleScript osascript <<EOD set userPass to text returned of (display dialog "Enter your password:" default answer "" with hidden answer) EOD # Run sysadminctl sysadminctl -secureTokenOn $3 -password $userPass -adminUser $4 -adminPassword $5
Best answer by ajanicke
I am severely disappointed in myself. For some reason I though in the OSA script the userPass would be honored as a variable in the script.. it's not this was a simple fix
#!/bin/bash # Prompt the user for their username and password using AppleScript and store the result in userPass userPass=$(osascript <<EOD set userPass to text returned of (display dialog "Enter your password:" default answer "" with hidden answer) EOD) # Run sysadminctl sysadminctl -adminUser $4 -adminPassword $5 -secureTokenOn $3 -password $userPass
  • October 11, 2023
Is the Bootstrap Token escrowed to Jamf?  If it is, all the user needs to do is sign in to the machine with an internet connection.  The Bootstrap Token will handle the rest.
ajanicke
  • October 11, 2023
I get Yes response to profiles status -type bootstraptoken on the ones that currently have the token enabled. I was hoping to test on a borked device today but all the tickets came in at once. Hope to do some testing tomorrow.
dennisnardi
Forum|alt.badge.img+15
  • October 11, 2023
I think your formatting might be a bit off? Below is what I've used for similar situations
userName=$(/usr/bin/stat -f%Su /dev/console) ## Get the logged in user's password via a prompt echo "Prompting ${userName} for their login password." userPass=`su \\- "${userName}" -c /usr/bin/osascript <<EOT tell application "System Events" activate set userPass to text returned of (display dialog "Please Input Your Login Password to Fix Account Issues" default answer "" with icon 2 with hidden answer) end tell EOT` echo "Adding user to FileVault and Granting SecureToken" ## This enables a SecureToken for the user sudo sysadminctl -adminUser $adminUser -adminPassword $adminPassword -secureTokenOn $userName -password $userPass
You just need to add your $adminUser and $adminPassword variables.
ajanicke
  • October 12, 2023
I tried on a device that the user does not have a secure token and it's showing DISABLED for the token and NO to the token being escrowed.
ajanicke
  • October 12, 2023
