cUrl Version via Exentension Attribute Not Reporting Back in Jamf
  • October 12, 2023
  • 60 views
I have tried writing a script about four different ways simply to report what version cURL is installed on Macs. I am scratching my head why the value is blank after running recon on various Macs.  Below is the script:
#!/bin/bash if command -v curl >/dev/null 2>&1; then curl_version=$(curl --version | awk 'NR==1{print $2}') echo "cURL is installed. Version: $curl_version" else echo "cURL is not installed." fi
Best answer by shannon_pasto
you have to echo your response inside
<result></result>
 So your 2 echo lines will be
echo "<result>cURL is installed. Version: $curl_version</result>"
and
echo "<result>cURL is not installed.</result>"
  • October 12, 2023
<result></result>
and
  • October 12, 2023
Thank You!!!!
Tonyyoung
  • October 12, 2023
I do believe that’s only going to check for the Apple installed curl, and won’t account for third party (homebrew, manually from GitHub, etc) versions of curl. Just keep that in mind.
