Unable to handle file upload - iPad Wallpaper Image Upload Error
  • October 13, 2023
  • 104 views
Hello,
As I have done previously, I am simply trying to upload a wallpaper image to use. However, I keep getting the following error:
Error-Wallpaper
Any thoughts on the issue? It is a .png file that is 5.47 KB (I am just using it to test, and it still fails). Thanks!
1 reply
  • October 16, 2023
Check the File Format and Size: Make sure the image you're trying to upload is in a supported format, such as JPEG or PNG. iPad wallpaper images should normally have a resolution that corresponds to the dimensions of your iPad's screen (e.g., 2048x1536 pixels for various models). If the image size is too huge, it may fail to upload.
Connect to a Stable Internet Connection: Upload errors can arise as a result of an unstable or slow internet connection. To avoid pauses during the upload process, make sure you're connected to a dependable Wi-Fi network.
Clear Browser Cache: If you are uploading the image using a web browser, clear your browser's cache and cookies. Caching issues can sometimes interfere with file uploads.
Provident Ecopolitan
