Dropbox deploy script
  • October 19, 2023
  • 91 views
bowie
Looking for a deployment script for Dropbox, so far I have found out that Dropbox does not provide an easy way to deploy their applications. Maybe someone has encountered the same problem before and has script/pkg that could help?
Best answer by karthikeyan_mac
@bowie You can refer the previous post. This can help you.
https://community.jamf.com/t5/jamf-pro/script-to-always-download-the-latest-version-of-dropbox/m-p/192322
Thanks
karthikeyan_mac
Forum|alt.badge.img+20
  • October 19, 2023
Covert the DMG to PKG and deploy using jamf
Steps to convert macOS DMG files to PKG files.
  • Go to the folder that contains the DMG file.
  • Double click the DMG file. It gets mounted as a virtual disk and reveals its contents.
  • Copy the .app file to the Applications folder in the macOS device.
  • Eject the DMG file by clicking on the eject button.
  • Open Terminal.
  • Build the PKG file using the productbuild command
sudo productbuild --component /path_to_installedapp/macapp.app / path_to_savedpackage/packagename.pkg
The two arguments specify the location of the installed .app file (path_to_installedapp/macapp.app) and the location to create the PKG file (path_to_savedpackage/packagename.pkg), respectively.
  • Provide the device login password and wait for a few seconds for the build to finish.
  • The PKG file gets created at the desired location.
bowie
  • October 20, 2023
Thanks
thank you, work like a charm
