Jamf Pro 11.1.0 Beta Now Available!
  • October 23, 2023
  • 13 replies
  • 79 views
ianhansen
Forum|alt.badge.img+21
Hello Jamf Nation!
Jamf Pro 11.1.0 Beta is now released
We're excited to announce that this beta includes Remote Assist and macOS Self Service Onboarding along with many other features and fixes.
How to join the beta: Enroll in the Beta Program under Product Feedback at account.jamf.com. Once you enroll you'll receive an invitation to join the Beta Forum, click "Join this group Hub" to gain access. Email beta@jamf.com with questions.
The beta program is covered by the Jamf non-disclosure agreement; please do not share any information regarding your testing on any public forum, including the non-beta areas of Jamf Nation. Use the Jamf Nation Beta Forum or contact Jamf via beta@jamf.com with any questions. Thank you to all who participate in this program!
SteveWalker
  • October 25, 2023
Does the Remote Assist feature have to be enabled somewhere? I don't see it. I tried 'enable remote desktop' but no dice.
  • October 25, 2023
Yeah you have to turn it on. Go to Settings > Computer Management > Security, there's a box to check for Remote assist there and then save.
SteveWalker
  • October 25, 2023
Thank you, that worked a treat!
  • October 26, 2023
Does remote assist have an additional licensing cost?
Person
  • October 31, 2023
No additional costs according to the Q&A
https://www.jamf.com/blog/meet-jamf-remote-assist/
  • November 2, 2023
Good morning,
It's been 4 times I registered for the beta program but I never see my instance updated until the final release.
Did I miss something ?
Msten
  • November 14, 2023
Is the user prompted to allow remote control before a remote session?
SteveWalker
  • November 14, 2023
Yes, they are.
  • November 17, 2023
Yes, they are.
So this won't help me log into a lab machine on my other campus?  There are use cases like mine that need the ability to get on the machine without a remote user accepting the connection. I'm more than happy with them somehow flashing warnings and notifications that the machine is being observed/controlled, but if this goes live as is, then it's mostly useless for me.
  • November 20, 2023
from here https://www.jamf.com/blog/meet-jamf-remote-assist/
If the end user is not logged into their computer, the remote screen sharing session will start as an unattended session if the admin is able to provide local account credentials
  • November 21, 2023
You need to enable that in the settings
Settings > Computer Management > Security > then tick Jamf Remote Assist
n_lecchi
  • November 27, 2023
We encountered some problems with JRA:
1. if screenshot shortcuts are disabled, JRA does not work.
2. with the shottr app enabled, user has multiple screenshots on the monitor.
3. The end user cannot stop screen sharing if the operator forgets the open session.
  • December 8, 2023
I can't see Remote Assist in our instance in Jamf Pro under Settings > Computer Management > Security, I'm an admin too?
