change software update server on a non jamf computer
  • October 11, 2010
  • 8 replies
  • 59 views
Dear all,
I removed a few macbooks from our database since they are gone from our site and now people tell me they cannot update via Software update since it stills tries to ask for the JSS server
I removed them from the JSS inventory and if I ask them to do the /usr/sbin/jamf removeFramework they claim they do not have it
so how can I change it back to APPLE software update?
thanks in advance
Carmelo Lopez Portilla
ITS EMBL Heidelberg
Tel. +49 (0) 6221 387 8444
Fax +49 (0) 6221 387 8517
email: lopez at embl.de
  • October 11, 2010
Can you send them command using ARD?
Jamf removeSWUSettings
This will allow it to point back to Apple.
Patrick Bachuwa
Client Technical Services
Sears Holdings Corporation
Michigan Campus
3000 W. 14 Mile Road
Royal Oak, MI 48073-1717
Phone: 248 637-0350
stevewood
Forum|alt.badge.img+38
  • October 11, 2010
Remove com.apple.SoftwareUpdate.plist from /Library/Preferences.
Steve
Sent from my iPad
Forum|alt.badge.img+15
  • October 11, 2010
Carmelo-
If you use MCX to enforce your software update you may have to remove Managed preferences too.
here is a overall jamf removal list
In Terminal: (mcx removal)
-- sudo dscl . -delete /Computers/localhost
to get Users name:
-- sudo dscl . list /Users
-- sudo dscl . -mcxdelete /Users/<Username>
In FInder:
-- Library/Managed Preferences - see if com.jamfsoftware.mcx is there. If Yes - Delete Managed Preferences Folder
sudo jamf removeSWUSettings
Final step to remove JAMF
/usr/sbin/jamf removeFramework /usr/sbin/jamf removeFramework
Additionally, there is a command will remove all Casper Suite related files from the client:
Reboot
Files installed by JAMF Software on managed clients
The following files/directories may be installed onto a computer managed by the Casper Suite:
jamf binary:
/usr/sbin/jamf
jamfVNC binary:
/usr/sbin/jamfvnc
JAMF startup script:
/System/Library/StartupItems/JAMF
Scheduled tasks, Policies, Restricted Software, Database backups (on the JSS only)
/System/Library/LaunchDaemons/com.jamfsoftware.task.*
Storage directory for Receipts, Composer Diffs, PreInstalled, etc:
/Library/Application Support/JAMF
Login/Logout hooks:
/var/root/Library/Preferences/com.apple.loginwindow.plist
Scripts:
/etc/scripts
Autorun Cache (if enabled):
/Library/Caches/com.jamfsoftware.autorun
JAMF configuration file:
/etc/jamf.conf
JAMF log file:
/var/log/jamf.log
Also, preference files for the Casper Suite applications (Casper.app, Casper Admin.app, Recon.app and Composer.app) are stored here:
/Library/Preferences/com.jamfsoftware.jamf.plist ~/Library/Preferences/com.jamfsoftware.*
Dan De Rusha
  • October 11, 2010
This was a big "win" for us too. Every once in a while we'd have a similar need and we couldn't get the machines completely off our SUS either.
Thanks a ton for the walkthrough Dan.
ben janowski
Senior Macintosh Support Technician
Kohl's Mac Support Team
262.703.1396 | benjamin.janowski at kohls.com
  • October 11, 2010
Thanks a lot
I had time to test this
I will do a script to automate it
Cheers
ITS EMBL Heidelberg
Forum|alt.badge.img+31
  • October 11, 2010
I think if there is time permitting you should just reimage your
machines with a basic, non managed, no jamf binary image when
decommissioning them. If not, a script can be automated to clean out
every user account, clear all management, clear out all jamf stuff, and
then enable the initial user setup screen.
Here would be an example....
# hard code variables for removing all user data and jamf data from a
decommissioned machine
JAMFList=" /usr/sbin/jamf /usr/sbin/jamfvnc /etc/jamf.conf /var/log/jamf.log /System/Library/StartupItems/JAMF /Library/Application Support/JAMF "
# get a list of users, in /Users
UserList=/bin/ls /Users | /usr/bin/grep -v "Shared"
# now loop to get rid of users
for u in ${UserList} ; do
/usr/bin/dscl . delete /Users/$u
# now delete their local data
/bin/rm -rf /Users/$u
done
# delete the computer records in MCX
dscl . delete /Computers
# now delete the managed preferences
/bin/rm -rf "/Library/Managed Preferences"
# now to unamange the jamf client and remove jamf files
# now to make sure all files are clean
for file in ${JAMFList}; do
if [[ -e ${file} ]]
then /bin/rm -rf ${file}
else /bin/echo "${file} not present" fi
# now enabled the Apple Setup Done file so it boots with the create a
user screen
/bin/rm -rf /var/db/.AppleSetupDone
This of course is not tested, but I think you could do something like
this. I just wrote it up really fast. So, please test it. Though my
initial thoughts would be to reimage the machine with a non managed, non
capser image when you get rid of it.
-Tom
  • October 11, 2010
Hi Thanks but I cannot redeploy the machines
They are private and users keep them after finishing at my company
Will work on the script
Thanks a lo
Cheers
ITS EMBL Heidelberg
  • October 13, 2010
I had changed the Software Update Server setting (but not via the JSS), and
this worked for me:
defaults delete /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
Tatian
Tatian Greenleaf
Associate Director of Technology
Saint Mark's School
(415) 472-8000 x1014
