Using Shared Mailbox with Microsoft Outlook Mobile
  • November 3, 2023
  • 100 views
ramroth
I try to add shared mailboxes on a managed iPhone in the Outlook App. The Exchange is hybrid On Premises and M365. But the Shared Mailbox option is missing on my devices.
If the devices are unmanaged or managed by Intune, the option appears.
Is there a config parameter missing to enable the function in Jamf Pro?
AJPinto
  • November 3, 2023
Have you raised a case with Microsoft? I'd wager that MS has the configuration profile to enable this baked into Intune, and some kind of authentication is coming from the comp portal SSOe. You probably need to upload a .mobileconfig for this to work with JAMF.
ramroth
  • November 3, 2023
Unfortunately MS asks for a support plan for questions about Exchange services.
I found out, that it may depend on the hybrid mailboxes.
My customer is very angry that I can not provide a solution but I think, it isn't a Jamf problem. So as he owns the MS Licenses, he must open a request there.
If no other user in Jamf Nation ever had this issue, there is no out of the box solution I can present ;-)
AJPinto
  • November 3, 2023
Yuck. Yes, this is not a JAMF "problem". Sounds like they came at you with an out of band situation and are trying to get angry at you about it. Deep down your customer likely knew they needed to contact MS, which is not a fun experience.
