SentinelOne Script (This could apply to any package... but my issue is with S1)
  • November 20, 2023
  • 7 replies
  • 88 views
This is my script I run for new installs:
sudo echo $4 > "/Library/Application Support/JAMF/Waiting Room/com.sentinelone.registration-token"
sudo /usr/sbin/installer -pkg "/Library/Application Support/JAMF/Waiting Room/Sentinel-Release-23-1-3-6816_macos_v23_1_3_6816.pkg" -target /
This is my script I run for upgrades:
sudo sentinelctl upgrade-pkg "/Library/Application Support/JAMF/Waiting Room/Sentinel-Release-23-1-3-6816_macos_v23_1_3_6816.pkg"
I have two policies.  One that is Cache.  One that is installed Cached.  That is for both scenarios above.  I am getting nothing but failure.
Is that something wrong with the scripts?  I don't have my error messages because I keep flushing them, but the cache one fails but I see where the file fully downloads.  That's all it's supposed to do.  The second script is supposed to install that file.  I used the cached file to manually install SentinelOne.  So, I know it's good.  Even without my error messages, can somebody look at the scripted code and tell me what I can do to fix the scripts?
Best answer by stevewood
This is a few years old now, but it worked solid for us. This would be used as an AFTER script on a single policy that CACHED the installer. $4 would be set to our S1 token and $5 would be the name of the package that was cached. This way you didn't have to change the script for each new release.
#!/bin/zsh log_file=/var/log/all-installSentinelOne-$(date +%Y%m%d-%H%M).log set -xv; exec 1> $log_file 2>&1 token="$4" package_name="$5" serial=$(system_profiler SPHardwareDataType | awk '/Serial\\ Number\\ \\(system\\)/ {print $NF}'); xpath() { # the xpath tool changes in Big Sur if [[ $(sw_vers -buildVersion) > "20A" ]]; then /usr/bin/xpath -e "$@" else /usr/bin/xpath "$@" fi } echo "$token" > /Library/Application\\ Support/JAMF/Waiting\\ Room/com.sentinelone.registration-token /usr/sbin/installer -pkg /Library/Application\\ Support/JAMF/Waiting\\ Room/$5 -target /
stevewood
Forum|alt.badge.img+38
  • November 20, 2023
  • November 21, 2023
That's brilliant.  I will share some screenshots to make sure I'm setting it up like you suggest.  I am only scoping this for new installs by using smart groups.
stevewood
  • November 21, 2023
Be sure to set the package to Cache not Install. You need the package to be in the Waiting Room folder or the install will fail.
And you might want to blur out the key value in parameter 4. Don't really want that to be out in the public.
  • November 21, 2023
Thanks!  I am going to be trying it today.  I don't seem to be able to edit my own posts... that's concerning.
  • November 21, 2023
Thank you.  Thank you.  Thank you.  It worked perfectly today.
I have struggled with the S1 installer for a while now.  Question is now, can the last line of the script be modified for update instead of install?  I am hopeful that S1 will auto-update but I may have to manually push out the update and I know the update command is different than the install command.
stevewood
  • November 27, 2023
@mmolenda yes, if you change that last line to match your upgrade line, it should work. Something like this:
sudo sentinelctl upgrade-pkg "/Library/Application Support/JAMF/Waiting Room/$5"
Obviously, test the heck out of that.
  • December 4, 2023
That's working beautifully as well.  Thank you.  My S1 issues have been resolved!
