Script runs successfully in terminal, and if pushed in policy, but doesn't work in Self-Service.
  • November 30, 2023
  • 57 views
I'm looking to make a set of options available to users via 2 policies in the Self Service app.
1 policy should allow the user to set a static IP address to the interface - I've written a script that inserts dummy values for now - this script runs successfully and alters the network settings as expected:
#!/bin/bash # sets test IP settings for Ethernet networksetup -setmanual Ethernet 10.10.10.10 255.0.0.0 127.0.0.0
The other policy should set the network settings back to DHCP for that interface - I wrote a script for this, which does not work:
#!/bin/bash # Set network settings back to DHCP networksetup -setdhcp Ethernet
This DHCP script reports as having run successfully (exit code 0) but the network settings on the device haven't changed.
If I run the single line with the networksetup command locally, in Terminal, it completes and changes the network settings as expected.
If I push the script out with a policy (as opposed to making it available in Self Service) it completes and changes the network settings as expected.
Any suggestions for troubleshooting / fixing this?
I've tried:
- using "ipconfig set en0 dhcp" instead - this hasn't worked
- giving networksetup the clientID parameter as suggested here - which didn't work: Solved: Automate Setting DHCP client ID to Hostname on Mac... - Jamf Nation Community - 172304
- running the script through ShellCheck - no errors found
I haven't yet tried:
- this suggestion, since I don't understand how to "Editing the policy in the JSS console then saving with no changes"Anyone else seeing Self Service policies with only... - Jamf Nation Community - 264005
Any help appreciated
A
geoff_widdowson
One golden rule to remeber when comparing terminal commands to self Service is Selft Service will always run as the root admin. Some terminal commands need to be run as the current logged in user. If this is the case you will have to force your self service script to run as the logged in user and not root admin.
Here is an example script on how to run as current user not root.
#variable for storing the current users name
currentuser=`stat -f "%Su" /dev/console`
#substituting as user stored in variable to modify plist
su "$currentuser" -c "<command to run>"
  • December 5, 2023
Geoff,
Thanks for that - I'll give that a go, though the first networksetup command runs as the admin user just fine, so I'm not sure that the second networksetup command to set it back to DCHP should need to be run as the logged in user.
