(1): '/usr/bin/hdiutil' error when trying to create an Adobe CS6 master collection DMG
  • July 6, 2016
  • 31 views
Trying to create an Adobe Master Collection CS6 DMG using composer but right at the when is about to finish creating the DMG, I get the error listed below:
Error: Command failed with error code (1): '/usr/bin/hdiutil'
I have read a few of the post on the forum but hasn't help me with the issue.
The weird thing is that if I do three software at the time (e.g. Adobe X Acrobat Pro, Photoshop and Illustrator, i'm able to do the DMG. Same goes if I try three different ones and so on.
I'm also able to do a PKG of the whole Adobe suite with no issues.
The reason I want a DMG is because we use Deploy Studio with a script that installs the suite and a pkg that contains the serial number. Unless someone can tell me how to deploy it via Casper?
Any ideas as to why the DMG would fail at the last step?
Regards,
Henry
davidacland
  • July 6, 2016
For CS6 I've always used Adobe Application Manager Enterprise Edition (AAMEE) which creates the serialised packages ready for deployment with Casper.
http://www.adobe.com/devnet/creativesuite/enterprisedeployment.html
PatrickD
  • July 6, 2016
I too ran into this with some Adobe stuff and a few other pieces of software. I do tend to use the AAMEE however check out this discussion, particularly the last comment by @pvillave which steps you through a work around.
https://jamfnation.jamfsoftware.com/discussion.html?id=7755
  • July 7, 2016
@PatrickD thanks:)
