Acrobat 9.4.0 Update Breaking SelfHeal Fix (Jody Rodgers)
  • October 13, 2010
  • 23 views
Hi All,
We're still a little new to the Mac's here at FDA and this is the first time we are updating Adobe Acrobat. We're running 9.3.1 now and trying to update to 9.4. We've tried various things to try and accomplish this to no avail::
- Just running the DMG's that we downloaded from Adobe. - Tried updating directly to 9.4 as well as updating incrementally through each version update - Each time Casper shows a success but the version doesn't update on the target machine
- Re-building the DMG by having Acrobat 9.3.1 installed capturing the state of the machine in composer then installing the updates, then capturing the changes - Tried this both with a Normal Snapshot as well as New and Modified snapshot creating a DMG to deploy - Again when we deployed this Caper showed success but the target machine was not updated
Aside of the self heal issues you are seeing how are you all deploying the package so that it is updating Acrobat for you?
Thanks for your help.
Jimmy Milto
FDA/OIM
Engineering Team
Message: 13
Date: Fri, 8 Oct 2010 23:32:48 +0000
1 reply
stevewood
Forum|alt.badge.img+38
  • October 13, 2010
I use a Python script developed by Greg Neagle over at the Managing OSX blog
http://managingosx.wordpress.com/2010/01/06/silent-installs-for-acrobat-pro-9-updates/)..) Basically, my steps are as follows:
  1. Create a BASH script that calls the Python script for each updater that
    I need to install.
  2. Create a Composer package that includes all of the updaters along with
    the Python script folder inside /Library.
  3. Add that package and the BASH script to Casper Admin.
  4. Create a policy that deploys the package and runs the BASH script as an
    After script.
Aside from the Self Heal issue that I started this thread with, I've had no
issues since starting to use this method of deploying patches to Acro 9.
Hope that helps.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
