Yule Logging
  • December 21, 2023
  • 10 views
brockwalters
As it is the holiday season, I wanted to offer up a little gratitude in the form of boilerplate code related to topics that come up in the macadmins #scripting & #bash channels again & again. I hope people find it here & find it useful.
1) Logging is always a hot topic. "How do I create a log for my script?" "Where should I write log output?" etc. Without saying this solution is definitive, the script below has a pattern that I have used over & over. In fact, I paste this block exactly into any script I create that needs logging. It uses tee along with exec & with a named pipe. Why? Well, I find this works in all situations to capture all foreground & background processes executed by the script & it creates a dedicated stream / file for the log output regardless of what the script is trying to do.
2) Jamf API. I said in an earlier post I had come up with the shortest, bestest version of making an API call with token auth. I was wrong. I made it shorter & betterer.
This script does not do anything remarkable - it removes Network Segments at their endpoint by name. This is also something that seems to come up repeatedly as the Jamf API docs could be a bit clearer on this subject. Using the object ID is straight forward but I think having a good example of using name as the identifier should be useful to some of you. Happy Whatever!
#!/bin/zsh # api.delete.network.segments @2023 # author: brock_walters@blah.com # created: 2023-11-07 # version: 9 # NOTE: This script is currently set in "test mode". To execute actual deletions the line in the script below starting with: # # /usr/bin/curl -LSs -X DELETE ... # # must be uncommented. # environment & data network_data_csv='/Users/Shared/building.subnet.data.csv' jamf_environment='https://server.blah.com:8443' ########################### ### DO NOT MODIFY BELOW ### ########################### # logging cpuname="$(/usr/sbin/scutil --get ComputerName)" srlnmbr="$(/usr/libexec/PlistBuddy -c 'print 0:serial-number' /dev/stdin <<< "$(/usr/sbin/ioreg -ar -d 1 -k 'IOPlatformSerialNumber')")" usrcrnt="$(/usr/bin/stat -f %Su /dev/console)" logexec="$(/usr/bin/basename "$0")" logpath="/private/tmp/${logexec%.*}.log" logpipe="/private/tmp/${logexec%.*}.pipe" /usr/bin/mkfifo "$logpipe" /usr/bin/tee -a < "$logpipe" "$logpath" & exec &> "$logpipe" printf "$(/bin/date "+%Y-%m-%dT%H:%M:%S") [START] logging %s\\ncomputer name: %s\\nserial number: %s\\ncurrent user: %s\\n" "$logexec" "$cpuname" "$srlnmbr" "$usrcrnt" >> "$logpath" logalrt(){ >&2 printf "$(/bin/date "+%Y-%m-%dT%H:%M:%S") [ALERT] %s\\n" "$1" >> "$logpath" } logexit(){ >&2 printf "$(/bin/date "+%Y-%m-%dT%H:%M:%S") [STOP] logging %s\\n" "$logexec" >> "$logpath" /bin/rm -rf "$logpipe"; /usr/bin/pkill -ail tee > /dev/null; exit } loginfo(){ >&2 printf "$(/bin/date "+%Y-%m-%dT%H:%M:%S") [INFO] %s\\n" "$1" >> "$logpath" } # jamf api jamfurl="$jamf_environment" jamfapi="$jamfurl/api/v1" jamfchk="$jamfurl/healthCheck.html" jamfrsc="$jamfurl/JSSResource" osaauth='Jamf Pro Authentication' osapswd='Please enter your Jamf API password:' osauser='Please enter your Jamf API username:' apiuser="$(/usr/bin/sudo -u "$usrcrnt" /usr/bin/osascript -e "display dialog \\"$osauser\\" default answer \\"\\" buttons {\\"Ok\\"} default button 1 with Title \\"$osaauth\\"" -e 'set theName to text returned of result')" apipswd="$(/usr/bin/sudo -u "$usrcrnt" /usr/bin/osascript -e "display dialog \\"$osapswd\\" default answer \\"\\" buttons {\\"Ok\\"} default button 1 with Title \\"$osaauth\\" with hidden answer" -e 'set thePswd to text returned of result')" b64auth="$(printf "%s" "$apiuser:$apipswd" | /usr/bin/iconv -t ISO-8859-1 | /usr/bin/base64)" tknauth="$(/usr/bin/plutil -extract 'token' raw - <<< "$(/usr/bin/curl -LSs -X POST -H 'Accept: application/json' -H "Authorization: Basic $b64auth" "$jamfapi/auth/token")")"; /bin/sleep 1.5 api_chk(){ printf "\\nChecking jamf api...\\n" ; } api_no(){ printf "The jamf server may not be available. Please try again. Exiting...\\n" ; } api_yes(){ printf "OK.\\n" ; } auth_chk(){ printf "\\nValidating jamf api credentials...\\njamf url: %s\\njamf api user: %s\\n" "$jamfurl" "$apiuser" ; } auth_no(){ printf "Please ensure that your credentials are correct & try again. Exiting...\\n\\n" ; } delete_no(){ printf "%s Network Segment Not Found.\\n\\n" "$ntwkstr" ; } delete_yes(){ printf "Deleting:\\n" ; } mtch_req(){ printf 'The server has not found anything matching the request.' ; } ntwk_csv(){ printf "\\nReading Network Segment names from %s\\n\\n" "$network_data_csv" ; } ops_done(){ printf "Operations complete.\\nInvalidating jamf api token...\\n" ; } token_no(){ printf "jamf api token status: UNAUTHORIZED\\n" ; } token_yes(){ printf "jamf api token status: OK\\n" ; } tknchk(){ tknhttp="$(/usr/bin/curl -LSs -X GET -H 'Accept: application/json' -H "Authorization: Bearer $tknauth" "$jamfapi/auth" -o '/dev/null' -w "%{http_code}")"; /bin/sleep 1.5 case "$tknhttp" in '200' ) token_yes ;; '401' ) token_no ;; * ) echo "$tknhttp" ;; esac } api_chk if /usr/bin/curl -LSs "$jamfchk" --connect-timeout 60 | /usr/bin/grep -q '\\[\\]' then api_yes else api_no; logexit fi auth_chk; tknchk if [ "$tknhttp" != '200' ] then logalrt; auth_no; logexit fi # operations IFS=$'\\n'; arrdata=($(/bin/cat "$network_data_csv")) ntwk_csv for i in "${arrdata[@]}" do ntwkstr="$(echo "$i" | /usr/bin/sed 's/,//g')" ntwkurl="$(echo "$i" | /usr/bin/sed 's/ /%20/g;s/,//g')" ntwkvar="$(/usr/bin/curl -LSs -X GET -H 'Accept: application/json' -H "Authorization: Bearer $tknauth" "$jamfrsc/networksegments/name/$ntwkurl"; /bin/sleep 1.5; echo)" if echo "$ntwkvar" | /usr/bin/grep -q "\\"name\\":\\"$ntwkstr\\"" then logalrt; delete_yes; echo "$ntwkvar" | /usr/bin/json_pp -t json #/usr/bin/curl -LSs -X DELETE -H 'Accept: application/json' -H "Authorization: Bearer $tknauth" "$jamfrsc/networksegments/name/$ntwkurl"; /bin/sleep 1.5; echo >> "$logpath" unset ntwkstr ntwkurl ntwkvar elif echo "$ntwkvar" | /usr/bin/grep -q "$(mtch_req)" then loginfo; delete_no unset ntwkstr ntwkurl ntwkvar; continue else logalrt 'Error.'; echo >> "$logpath" unset ntwkstr ntwkurl ntwkvar; continue fi done ops_done /usr/bin/curl -LSs -X POST -H 'Accept: application/json' -H "Authorization: Bearer $tknauth" "$jamfapi/auth/invalidate-token"; /bin/sleep 1.5; tknchk; echo; logexit
1 reply
brockwalters
  • December 22, 2023
PS. I failed to mention the input should just be a single column ".csv" file of single quoted Network Segment names & you put the path to that file in the network_data_csv variable at the top pf the script.
