Bulk unmanage computers
  • January 3, 2024
  • 113 views
Hello, is there any way to make multiple computers unmanaged in JAMF without unticking the box for each of them individually or deleting them completely?
Previously, there was a way to edit management account via mass action and set it to blank, but now that's not an option anymore.
All those computers are un-enrolled already, however still listed as managed in JAMF database, and we are talking about hundreds of those - going through each of them would a pain..
Thank you.
Best answer by jamf-42
and.. bit of digging.. and we have this thread..  as expected its API time..
https://community.jamf.com/t5/jamf-pro/unmanaging-macos-devices-through-api/td-p/282745/page/2
This looks to work for my use case.. obviously some tweaking required..
#!/bin/bash # This can't be run from Jamf. We're just storing it here. # Download it to your Mac and run it in Terminal. echo "Enter JSS username:" read USERNAME echo "Enter JSS password:" read -s PASSWORD TOKEN_EXPIRATION_EPOCH="0" function getBearerToken() { RESPONSE=$(curl -s -u "$USERNAME":"$PASSWORD" "https://jssurl:8443/api/v1/auth/token" -X POST) OS_MAJOR_VERSION=$(sw_vers -buildVersion | cut -c 1-2) echo "OS Major Version: $OS_MAJOR_VERSION" if [ "$OS_MAJOR_VERSION" -lt 21 ]; then # Get the token info BEARER_TOKEN=$(echo $RESPONSE | python -c 'import json,sys;obj=json.load(sys.stdin);print obj["token"]') # Get the expiration date TOKEN_EXPIRATION=$(echo $RESPONSE | python -c 'import json,sys;obj=json.load(sys.stdin);print obj["expires"]') # If we are running Monterey or later then we can use plutil to parse json else # Get the token info BEARER_TOKEN=$(echo "$RESPONSE" | plutil -extract token raw -) # Get the token expiration date TOKEN_EXPIRATION=$(echo "$RESPONSE" | plutil -extract expires raw - | awk -F . '{print $1}') fi TOKEN_EXPIRATION_EPOCH=$(date -j -f "%Y-%m-%dT%T" "$TOKEN_EXPIRATION" +"%s") } function checkTokenExpiration() { NOW_EPOCH_UTC=$(date -j -f "%Y-%m-%dT%T" "$(date -u +"%Y-%m-%dT%T")" +"%s") if [[ TOKEN_EXPIRATION_EPOCH -gt NOW_EPOCH_UTC ]] then echo "Token valid until the following epoch time: " "$TOKEN_EXPIRATION_EPOCH" else echo "No valid token available, getting new token" getBearerToken fi } function invalidateToken() { RESPONSE_CODE=$(curl -w "%{http_code}" -H "Authorization: Bearer ${BEARER_TOKEN}" "https://rcimac.rci.rogers.com:8443/api/v1/auth/invalidate-token" -X POST -s -o /dev/null) if [[ ${RESPONSE_CODE} == 204 ]] then echo "Token successfully invalidated" BEARER_TOKEN="" TOKEN_EXPIRATION_EPOCH="0" elif [[ ${RESPONSE_CODE} == 401 ]] then echo "Token already invalid" else echo "An unknown error occurred invalidating the token" fi } echo "Getting API token..." checkTokenExpiration # Paste in a list of Mac SNs to be removed from management: unmanage=( SN##### SN##### SN##### ) for SERIAL in ${unmanage[@]} do # This next commented code is to get the serial number of the Mac from which the script # is running in the case of performing the script on this local Mac to remove it from management. # I've turned it off in favour of using an array of provided SNs of other Macs. See above. # to remove from management. # Get local serial number: # SERIAL=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}') # /bin/echo "Serial number is $SERIAL" # Get JAMF ID of device from API looked by SN found locally or provided in # $unmanage array: JAMF_ID=$(curl -X GET "https://rcimac.rci.rogers.com:8443/JSSResource/computers/serialnumber/$SERIAL" -H "accept: application/xml" -H "Authorization: Bearer $BEARER_TOKEN" | xmllint --xpath '/computer/general/id/text()' -) # API call to de-select "Allow Jamf Pro to perform management tasks" in the JSS for this device: curl --request PUT --url "https://rcimac.rci.rogers.com:8443/JSSResource/computers/id/$JAMF_ID" -H "Content-Type: application/xml" -H "Accept: application/xml" -H "Authorization: Bearer $BEARER_TOKEN" -d '<computer><general><remote_management><managed>false</managed></remote_management></general></computer>' /bin/echo "JAMF ID for $SERIAL is $JAMF_ID and it is now unmanaged in the JSS" done # Bin the token /bin/echo "Invalidating API token..." invalidateToken /bin/echo "Done." exit 0;
jamf-42
  • January 4, 2024
..when did this get removed from Mass Action?? and why!
Im looking for the same.. guess this is going to end up with a script / API call..
jamf-42
  • January 5, 2024
  • January 16, 2024
Thank you for answering, you made my day.
