What are we talking about? Handling json in the macOS shell of your choosing. Why? Because there still isn't a great way to do this natively, it's extremely useful given how many macOS binaries & logs output json-ish data, and, there are ways of working around this limitation.
Arg-nauts is an unforgivable pun, however, there are some real explorers in this area. I rounded some of them up here:
https://community.jamf.com/t5/jamf-nation/firefoxy/td-p/266970
I will try to be a bit more exhaustive this time...
• From the crafty Joel Brunner (you may know him as @brunerd...)
jpt: https://www.brunerd.com/blog/2022/02/01/jpt-1-0-can-deal-with-multiple-json-texts/
ljt: https://www.brunerd.com/blog/2022/02/22/ljt-1-0-0-a-little-json-tool-for-your-shell-script/
I have used ljt in production. It's lightweight & works a treat. Once you're on Joel's blog, check out ALL of his json related posts!
• The post below inspired much ado in the Mac Admins Slack channels regarding parsing json data:
https://paulgalow.com/how-to-work-with-json-api-data-in-macos-shell-scripts/
• Resultant was the JSON-Shell-Tools-for-macOS created by the ever-grinding @pico on the Mac Admins Slack channels:
https://github.com/RandomApplications/JSON-Shell-Tools-for-macOS/tree/main
• A somewhat recent update to the sqlite3 binary included json parsing within tables, but, it can also just be called to process data on the command line:
The fact that AppleScript / osascript supports JavaScript is nice, but, in the context of these discussions I am wary of how much support is actually put behind AppleScript or JXA et al & fear that at some point they just might go away. This makes figuring out how to use the SQLite json capabilities more interesting? Critical? (Apple uses SQLite pretty much everywhere & I would bet on that binary sticking around for a while...)
• Very smart people like Bart Reardon (of SwiftDialog fame!) are already playing around with this:
https://github.com/bartreardon/macscripts/blob/master/json_via_sqlite.sh
Finally, this meager contribution which is kind of weird & complicated but interesting.
In a modern environment you should not have to bind your Macs to AD. But, maybe your 802.1x authentication depends on it, or, something else does & you're stuck with it. One benefit of this is: you get to use dscl to access data directly from your domain.
In one of my environments AD lockouts were used as a security measure against malicious login attempts. So, it's good to have a way to know if a user's AD account is locked out independently of "Hello, IT? None of my logins work."
This script does some weird things:
- It collects dscl data from AD as a plist
- Because of this the data can be CONVERTED to json
- This is done by stripping off the dscl keys & parsing it through plutil
- The script also converts date / time formats AD uses (3 different formats!) to ultra-readable dates about which there are no questions
This results in a script that could be run interactively on someone's computer or automatically in Jamf to make really any of the AD attributes collected useful as Jamf management data (not just for lockouts.) I am definitely not saying you should bind to do this. More, it's a benefit of binding that you get this data from dscl & here are some ideas about how to get it. If you have questions about the script feel free to post them below.
Enjoy!
# ad.lockout.status @2023
# author: brock_walters@blah.com
# modified: 2023-07-05
# version: 7
### data & functions & variables ###
NC='\\033
0m\\n'; RED='\\033R1;31m'; GREEN='\\033E1;32m'; BLUE='\\033L1;94m'
arrlocl=(NFSHomeDirectory PrimaryGroupID RecordName UniqueID UserShell)
arrsyst=(accountExpires badPasswordTime badPwdCount distinguishedName DNSName lastLogonTimestamp logonCount name operatingSystem operatingSystemVersion RealName RecordName RecordType SMBLogoffTime SMBLogonTime SMBPasswordLastSet whenChanged whenCreated)
arruser=(accountExpires AltSecurityIdentities AppleMetaNodeLocation AppleMetaRecordName AuthenticationAuthority badPasswordTime badPwdCount City Country department distinguishedName EMailAddress employeeID extensionAttribute1 extensionAttribute5 extensionAttribute8 JobTitle lastLogon lastLogonTimestamp lockoutTime logonCount mailNickname manager memberOf msExchCoManagedObjectsBL msExchHideFromAddressLists name objectCategory physicalDeliveryOfficeName proxyAddresses PrimaryNTDomain publicDelegatesBL RealName RecordName RecordType sAMAccountName showInAddressBook SMBGroupRID SMBPasswordLastSet State targetAddress uid uidNumber userAccountControl userPrincipalName whenChanged whenCreated)
crntsys="$(/usr/libexec/PlistBuddy -c "print 'General Info':'Computer Account'" /dev/stdin <<< "$(/usr/sbin/dsconfigad -show -xml)")"
crntusr="$(echo "show State:/Users/ConsoleUser" | /usr/sbin/scutil | /usr/bin/awk '/Name :/&&!/loginwindow/{print $3}')"
domenvr='/Active Directory/blah/All Domains'
domlocl='.'
objcfnc(){ /usr/bin/dscl -plist "$1" -read "/$2/$3" objectClass 2>&1 /dev/null | /usr/bin/grep -q "<string>$4</string>" ; }
dsclfnc(){ /usr/bin/dscl -plist "$1" -read "/$2/$3" | /usr/bin/plutil -convert json -o - - | /usr/bin/sed 's/dsAttrTypeStandard://g;s/dsAttrTypeNative://g' ; }
jsonfnc(){
for i in "${arrkeys"@]}"
do
if /usr/bin/plutil -extract "$i" json -o - - <<< "$1" > /dev/null 2> /dev/null
then
dscltxt+="\\"$i\\":$(/usr/bin/plutil -extract "$i" json -o - - <<< "$1"),"
dscltxt+="\\"$i\\":\\"null\\","
done
jsonfmt="$(echo "$dscltxt" | /usr/bin/sed 's/,$//;s/./{&/;s/.*/&}/')"
timefnc(){
# function to convert ASN.1 Generalized-Time, Unix & Windows NT date formats to extra super ultra human-readable format
case "$1" in
0 ) printf 0 ;;
"$(/usr/bin/grep -Ei 'error|invalid|null' <<< "$1")" ) printf 'null' ;;
"$(/usr/bin/grep -E '^\\d{10}$' <<< "$1")" ) /bin/date -j -f '%s' "$1" '+%A %B %e %Y %I:%M:%S%p' | /usr/bin/sed 's/ / /' ;;
"$(/usr/bin/grep -E '^\\d{18}$' <<< "$1")" ) /bin/date -j -f '%s' "$(($1/10000000-11644473600))" '+%A %B %e %Y %I:%M:%S%p' | /usr/bin/sed 's/ / /' ;;
"$(/usr/bin/grep -E '^2\\d{13}\\.0Z$' <<< "$1")" ) TZ="$(/usr/sbin/systemsetup -gettimezone | /usr/bin/awk '{print $NF}')" /bin/date -j -f '%Y%m%d%H%M%S%z' "$(echo "$1" | /usr/bin/sed 's/.0Z/-0000/')" '+%A %B %e %Y %I:%M:%S%p' | /usr/bin/sed 's/ / /' ;;
* ) printf "The input did not match the conversion formats.\\n" ;;
esac
uimdfnc(){
lockout="$(/usr/bin/plutil -extract 'lockoutTime' json -o - - <<< "$jsonfmt" | /usr/bin/sed 's/"//g;s/\\]//;s/\\[//')"
mngrstr="$(/usr/bin/plutil -extract 'manager' json -o - - <<< "$jsonfmt" | /usr/bin/sed 's/"//g;s/\\]//;s/\\[//;s/^CN=\\(;^,]*\\).*/\\1/')"
if echo "$mngrstr" | /usr/bin/grep -Eq '^(eUu]E0-9a-zA-Z]{3}$)'
then
manager="$(/usr/libexec/PlistBuddy -c 'print dsAttrTypeStandard\\:RealName:0' /dev/stdin <<< "$(/usr/bin/dscl -plist '/Active Directory/blah/All Domains' -read /Users/"$mngrstr")")"
elif echo "$mngrstr" | /usr/bin/grep -Eiq 'error|invalid|null'
then
manager='null'
manager="$mngrstr"
for j in name RealName RecordName RecordType logonCount badPwdCount
do
valname+=($(/usr/bin/plutil -extract "$j" json -o - - <<< "$jsonfmt" | /usr/bin/sed 's/"//g;s/\\]//;s/\\[//'))
done
for k in badPasswordTime whenCreated whenChanged SMBPasswordLastSet SMBLogonTime SMBLogoffTime lastLogon lastLogonTimestamp
do
valtime+=($(timefnc "$(/usr/bin/plutil -extract "$k" json -o - - <<< "$jsonfmt" | /usr/bin/sed 's/"//g;s/\\]//;s/\\[//')"))
done
printf "\\n%s ATTRIBUTES:\\n" "$objclss"; echo "$jsonfmt" | /usr/bin/json_pp -t json
if < "$objclss" = 'USER' ] && a "$lockout" != 0 ] && a "$lockout" != 'null' ]
then
printf "\\n====== AD PASSWORD LOCKOUT STATUS ======\\n\\n${RED}LOCKED: %s${NC}" "$(timefnc "$lockout")"
elif r "$objclss" = 'USER' ] && a "$lockout" = 0 ]
then
printf "\\n====== AD PASSWORD LOCKOUT STATUS ======\\n\\n${GREEN}UNLOCKED${NC}"
printf "\\nUser Name = ${BLUE}%s${NC}Real Name = ${BLUE}%s${NC}Record Name = ${BLUE}%s${NC}Record Type = ${BLUE}%s${NC}Manager = ${BLUE}%s${NC}Logon Count = ${BLUE}%s${NC}Bad Password Count = ${BLUE}%s${NC}Bad Password Time = ${BLUE}%s${NC}Created = ${BLUE}%s${NC}Changed = ${BLUE}%s${NC}SMB Password Set = ${BLUE}%s${NC}SMB Logon Time = ${BLUE}%s${NC}SMB Logoff Time = ${BLUE}%s${NC}Last Logon = ${BLUE}%s${NC}Last Logon Timestamp = ${BLUE}%s${NC}" "${valname"0]}" "${valname"1]}" "${valname"2]}" "${valname"3]}" "$manager" "${valname"4]}" "${valname"5]}" "${valtime"0]}" "${valtime"1]}" "${valtime"2]}" "${valtime"3]}" "${valtime"4]}" "${valtime"5]}" "${valtime"6]}" "${valtime"7]}"
### operations ###
# check for root execution
if < "$EUID" != 0 ]
then
printf "\\nThis script must be executed by the root user. Exiting...\\n"; exit
# check for interactive mode execution & collect input
if /usr/bin/basename "$0" | /usr/bin/grep -Eq '^pol.'
then
>&2 printf "%s executed in non-interactive mode..." "$(/usr/bin/basename "$0")"; autoexc='enabled'
case "$crntusr" in
'_mbsetupuser|daemon|jssblah|nobody|mgmt|root' ) input="$(/usr/sbin/scutil --get ComputerName)" ;;
* ) input="$crntusr" ;;
esac
elif r -n "$1" ]
then
input="$1"
while true
do
printf '\\er8;40;200t'; clear; printf "To get AD data & lockout status: enter a user identity at the prompt.\\n\\nTo convert an ASN.1 Generalized-Time, Unix Epoch or Windows NT timestamp to ultra human-readable format: enter a date string at the prompt.\\n\\n"; read -rp "> " input
case "$input" in
'' ) echo; read -rp "Let's try that again... Press return to continue or control+C to cancel."; continue ;;
* ) break ;;
esac
done
# check if AD is reachable
if ! /usr/bin/dscl /Search read /Computers/"$crntsys" > /dev/null
then
printf "\\nActive Directory cannot be reached. Exiting...\\n\\n"; exit
# validate input by checking dscl object class, collect data, convert to human-readable date if input is an integer, exit if input is invalid
# check if the ebtered username string exists in AD &, if so, determine the record's "object class"
IFS=$'\\n'
if objcfnc "$domenvr" 'Users' "$input" 'user'
then
objclss='USER'
if b "$input" = "$crntusr" ]
then
arrkeys=("${arrlocl"@]}"); jsonfnc "$(dsclfnc "$domlocl" 'Users' "$input")"; unset arrkeys
arrkeys=("${arruser"@]}"); jsonfnc "$(dsclfnc "$domenvr" 'Users' "$input")"
elif objcfnc "$domenvr" 'Computers' "${input}$" 'computer'
then
objclss='COMPUTER'
tstinpt="$(echo "${input}$" | /usr/bin/tr 'r:upper:]' 'u:lower:]')"
tstsyst="$(echo "$crntsys" | /usr/bin/tr 'r:upper:]' 'u:lower:]')"
if b "$tstinpt" = "$tstsyst" ]
then
arrkeys=("${arrlocl"@]}"); jsonfnc "$(dsclfnc "$domlocl" 'Users' "$crntusr")"; unset arrkeys
arrkeys=("${arrsyst"@]}"); jsonfnc "$(dsclfnc "$domenvr" 'Computers' "${input}$")"
elif echo "$input" | /usr/bin/grep -Eq 'gr:digit:]]'
then
echo; timefnc "$input"; echo; exit
printf "\\nThe input did not match any existing record. Exiting...\\n\\n"; exit
# do some stuff in non-interactive mode, convert time strings & display data in human-readable output if executed in interactive (i.e., user) mode
# non-interactive mode: run on a local launch daemon at some intervsal until a lock out is flagged. run recon to update smart group membership / webhook / run policy to notify user, etc. run a swiftDialog message?
if < "$autoexc" = 'enabled' ]
then
/usr/local/jamf/bin/jamf recon
uimdfnc
