Have a curious problem. Running 9.72, certain clients are failing to run any Self Service policies and when I check the ~/Library/Logs/JAMF/JAMFApplications.log I see errors like this:
2015-06-16 17:04:31 <com.jamfsoftware.selfservice>: Policy "OS X 10.10 (Yosemite) Upgrade" failed: sh: /Library/Application Support/JAMF/tmp/10225.tmp: Permission denied
cp: /Library/Preferences/SystemConfiguration/preferences.plist.old: Permission denied
There is a problem with your syntax.
Error: This application must be run as root. Try the sudo command.
Type "jamf help" for more information.
This will happen for all policies in Self Service. If an administrator logs in, they can run them.
Curiously if I delete Self Service and run sudo jamf policy to install it, the problem goes away. Any ideas what could be going on here?
