Has anyone else had issues with a very slow to load dashboard with Jamf Pro 11, nothing I seem to do improves the load time as well as information that was present before, like build number etc... are all missing, which is fine, but it does make it give you less information and with slow load times it's just very cumbersome to use now.
Any potential fixes for this, cleared cache, incognito, different browsers, no hardware acceleration, different OS, nothing seems to work on load times.
I wanted to provide an update a year later. I removed a lot of the widgets and started fresh, and it worked really well after that. It seems I might have had too many queries loading each time. Whoops!
