Help with new Wifi Configuration Profile for iOS
  • January 29, 2024
  • 0 replies
  • 29 views
Hello,
My organization is deploying a new WiFi system/SSID.
I created a configuration profile with the certificate payload and the WiFi payload.
I am having trouble configuring it to connect to our SSID. The issue I am running into is that the device connect successfully the very first time, but every time the device tries to reconnect to the Wifi, it just hangs and is unable to connect. We do not want to use the "Use Per-Connection Password" option, since that requires that credentials be entered every single time the device reconnects to the SSID.
We want it setup where the user has to put in their username/password credentials, but just once.
I've gotten set up where they have to enter it in every time, but we want to avoid that since our devices are usually assigned to a specific person.
We are using PEAP authentication with AD accounts. I am using the $USERNAME variable for the username field.
Any help would be appreciated.
