Upgrade jamf pro from 10.46 to 11
  • February 2, 2024
  • 31 views
Is there anything more you got to install/upgrade before moving from jamf pro 10.46 to 11.2. When i'm reading https://learn.jamf.com/bundle/technical-articles/page/Incremental_Upgrade_Scenarios_for_Jamf_Pro_10-0-0_or_Later.html i cannot find anything that we have to do.
Kind regards Joachim
sdagley
  • February 2, 2024
@Bolagsverket That article does indicate that directly upgrading from 10.46 to 11.x should work. Just be sure to make backups of your environment first in case it's wrong.
pete_c
  • February 2, 2024
Consider running Prune to look for any unused database objects: https://github.com/BIG-RAT/Prune
i would recommend to check your MySQL Version. Since 10.46 is still compatible with MySQL 5.7.x while in 11.2 it is already minimum supported and, at least from what i read, the updates coming after February will drop the support for MySQL 5. So depending on your system you may need to migrate to SQL 8 beforehand
