Send help: User initiated enrollment - personally owned
  • February 3, 2024
  • 0 replies
  • 23 views
Hey all together,
im pretty new to Jamf Pro so be a little bit patient with me. ;)
Our company wants to enroll the devices in the BYOD context.
For my understanding it was needed to configure the user initiated enrollment - personally owned.
So far, so good. I can access the /enroll URL and sign in with my connected SSO / Entra
Afterwards i log in with my fresh created managed Apple ID
Everything seems to work fine... but know my understanding problem:
Its installing two MDM profiles. One is called "MDM profile" and the one i created.
But its not applying my for example code restrictions i set in the configuration profile.
So im just confused where im doing the mistake.
Don't know if there is a coherence:
I saw, that there are two different "methods" if we are talking about the BYOD mobile device connection. But i dont have to host a webserver on my own for this right?
Hope you can help me through the Jamf jungle.
