Extension attribute for FileVault 2 status
  • November 9, 2011
  • 5 replies
  • 41 views
Forum|alt.badge.img+33
One of the items I was planning to mention during my FileVault 2 talk was that I've written an extension attribute to provide information about FileVault 2. To celebrate JAMF Nation's new site, here it is in advance!
It's also available from my GitHub repo at the following address. All updates to this extension attribute will be posted there:
https://github.com/rtrouton/rtrouton_scripts/tree/master/rtrouton_scripts/filevault_2_encryption_check/Casper%20Extension%20Attribute
CORESTORAGESTATUS="/private/tmp/corestorage.txt"
ENCRYPTSTATUS="/private/tmp/encrypt_status.txt"
ENCRYPTDIRECTION="/private/tmp/encrypt_direction.txt"
OS=`/usr/bin/sw_vers | grep ProductVersion | cut -c 17-20`
CONTEXT=`diskutil cs list | grep -E "Encryption Context" | awk '{print $3}'`
ENCRYPTION=`diskutil cs list | grep -E "Encryption Type" | awk '{print $3}'`
CONVERTED=`diskutil cs list | grep "Size (Converted)" | awk '{print $5, $6}'`
SIZE=`diskutil cs list | grep "Size (Total)" | awk '{print $5, $6}'`
# Checks to see if the OS on the Mac is 10.7 or not.
# If it is not, the following message is displayed without quotes:
# "FileVault 2 Encryption Not Available For This Version Of Mac OS X"
if [ "$OS" != "10.7" ]; then
  echo '<result>'FileVault 2 Encryption Not Available For This Version Of Mac OS X'</result>'
if [ "$OS" = "10.7" ]; then
  diskutil cs list >> $CORESTORAGESTATUS
    # If the Mac is running 10.7, but not does not have
    # any CoreStorage volumes, the following message is
    # displayed without quotes:
    # "FileVault 2 Encryption Not Enabled"
    if grep -iE 'No CoreStorage' $CORESTORAGESTATUS; then
       echo '<result>'FileVault 2 Encryption Not Enabled'</result>'
    # If the Mac is running 10.7 and has CoreStorage volumes,
    # the script then checks to see if the machine is encrypted,
    # encrypting, or decrypting.
    # If encrypted, the following message is
    # "FileVault 2 Encryption Complete"
    # If encrypting, the following message is
    # "FileVault 2 Encryption Proceeding."
    # How much has been encrypted of of the total
    # amount of space is also displayed. If the
    # amount of encryption is for some reason not
    # known, the following message is
    # "FileVault 2 Encryption Status Unknown. Please check."
    # If decrypting, the following message is
    # "FileVault 2 Decryption Proceeding"
    # How much has been decrypted of of the total
    # If fully decrypted, the following message is
    # "FileVault 2 Decryption Complete"
    if grep -iE 'Logical Volume Family' $CORESTORAGESTATUS; then
      if [ "$CONTEXT" = "Present" ]; then
        if [ "$ENCRYPTION" = "AES-XTS" ]; then
          diskutil cs list | grep -E "Conversion Status" | awk '{print $3}' >> $ENCRYPTSTATUS
            if grep -iE 'Complete' $ENCRYPTSTATUS; then
              echo '<result>'FileVault 2 Encryption Complete'</result>'
              if  grep -iE 'Converting' $ENCRYPTSTATUS; then
                diskutil cs list | grep -E "Conversion Direction" | awk '{print $3}' >> $ENCRYPTDIRECTION
                  if grep -iE 'Forward' $ENCRYPTDIRECTION; then
                    echo '<result>'FileVault 2 Encryption Proceeding. $CONVERTED of $SIZE Remaining'</result>'
                    echo '<result>'FileVault 2 Encryption Status Unknown. Please check.'</result>'
            if [ "$ENCRYPTION" = "None" ]; then
                if grep -iE 'Backward' $ENCRYPTDIRECTION; then
                  echo '<result>'FileVault 2 Decryption Proceeding. $CONVERTED of $SIZE Remaining'</result>'
                elif grep -iE '-none-' $ENCRYPTDIRECTION; then
                  echo '<result>'FileVault 2 Decryption Completed'</result>'
# Remove the temp files created during the script
if [ -f /private/tmp/corestorage.txt ]; then
   srm /private/tmp/corestorage.txt
if [ -f /private/tmp/encrypt_status.txt ]; then
   srm /private/tmp/encrypt_status.txt
if [ -f /private/tmp/encrypt_direction.txt ]; then
   srm /private/tmp/encrypt_direction.txt
  • November 9, 2011
Correct link:
  • November 10, 2011
Kickass, thanks Rich!
  • Employee
  • November 10, 2011
Hey Rich - this is awesome. Would you mind uploading it to the Mac OS X Third-Party Product section?
  • November 10, 2011
Jake,
I'm having trouble uploading the script in the third party products section. What's the correct procedure to attach and upload a shell script?
Thanks,
Rich
Forum|alt.badge.img+15
  • Employee
  • November 11, 2011
Fantastic presentation, Rich. I'm adding a link to your blog with the slides for future reference:
http://derflounder.wordpress.com/2011/11/10/slides-from-the-filevault-2-session-at-jamfs-2011-national-user-conference/
Thanks for your great contribution to #jnuc 2011!
