Blocking Google Drive app
  • March 11, 2024
  • 6 replies
  • 65 views
I am unable to block Google Drive app using Restricted Software in Jamf Pro
I have tried "Google Drive", "Google Drive.app", "Google Drive*" for process name but none of these works.
Previously, adding "Backup and Sync" for process name was blocking the app.
Please let me know if you have any suggestions or workarounds.
jamf-42
  • March 11, 2024
restricted software is always a bit hit and miss.. a policy with 'jamf manage' can help...  'google drive' is the binary process.. but moving up a level.. how is it installed?
  • March 11, 2024
Yeah, I have tried recon and 'jamf manage'. Unfortunately, wasn't helpful.
dmg was downloaded directly from google and installation happened via package
jamf-42
  • March 11, 2024
you using kill and delete.. otherwise the lauchdeamon will respawn the process..  that won't remove the rest of it.. better to block the installer..
  • March 11, 2024
I got kill and restrict
It is working for other apps
jamf-42
  • March 11, 2024
there is a launchd.. so.. unless you bin it.. it will come back.. try Goole Drive.app with delete.. this will only remove the app and not the launchd, clean up via a script.. but only admins can install.. so.. again. another level... how is it being allowed to be in installed...
  • March 11, 2024
Sure, will try that. Thanks for prompt responses. Appreciate it!
