Set Terminal disc access in Jamf
  • March 19, 2024
  • 4 replies
  • 76 views
Franky779
Jamf is supporting default scripts for checking time machine backups. But with new versions of mac os this won´t work beuacse diskutil is using PlistBuddy. This has no disc access. If i enable Terminal in full disk access those scripts are working again.
Without disc access
With disc access
How can i set Terminal do full disc access via configuration profile?
Greets Frank
jamf-42
  • March 19, 2024
you don't want to grant terminal full disk access.. thats 'a bad idea'
not sure why plistbuddy is requiring access, but this does not.. you'll need to work that a bit to get the result you need, but you get the idea.
defaults read /Library/Preferences/com.apple.TimeMachine.plist | grep LastDestinationID
Franky779
  • March 20, 2024
This is the script that Jamf offers in Custom attributes. This does not work anymore with newer MacOS Version.
#!/bin/sh enabled=`/usr/bin/defaults read /Library/Preferences/com.apple.TimeMachine AutoBackup` if [ "$enabled" == "1" ]; then # Determine the OS version since the destination key name differs on OS OS=`/usr/bin/sw_vers -productVersion | /usr/bin/colrm 5` if [[ "$OS" < "10.7" ]]; then backupDestination=`/usr/sbin/diskutil info $(/usr/bin/defaults read /Library/Preferences/com.apple.TimeMachine "DestinationVolumeUUID") | grep "Mount Point" | /usr/bin/cut -c 30-` validateDestination=`/usr/sbin/diskutil info $(/usr/bin/defaults read /Library/Preferences/com.apple.TimeMachine "DestinationVolumeUUID") | awk '{print $1, $2}'` elif [ "$OS" == "10.7" ]; then backupDestination=`/usr/sbin/diskutil info $(/usr/libexec/PlistBuddy -c "Print DestinationVolumeUUIDs:0" /Library/Preferences/com.apple.TimeMachine.plist) | grep "Mount Point" | /usr/bin/cut -c 30-` validateDestination=`/usr/sbin/diskutil info $(/usr/libexec/PlistBuddy -c "Print DestinationVolumeUUIDs:0" /Library/Preferences/com.apple.TimeMachine.plist) | awk '{print $1, $2}'` elif [[ "$OS" > "10.7" ]]; then backupDestination=`/usr/sbin/diskutil info $(/usr/libexec/PlistBuddy -c "Print Destinations:0:DestinationUUIDs:0" /Library/Preferences/com.apple.TimeMachine.plist) | grep "Mount Point" | /usr/bin/cut -c 30-` validateDestination=`/usr/sbin/diskutil info $(/usr/libexec/PlistBuddy -c "Print Destinations:0:DestinationUUIDs:0" /Library/Preferences/com.apple.TimeMachine.plist) | awk '{print $1, $2}'` fi ​ if [ "$validateDestination" == "Could not" ];then echo "<result>Destination not mounted</result>" else echo "<result>$backupDestination</result>" fi else echo "<result>Not enabled.</result>" fi
I will try your snipped. Thanks
Franky779
  • March 20, 2024
OK, i changed the scripts and i want to share them if somebody else wants to check time machine status
Last succesfull backup
#!/bin/bash # Plist-Datei, die das Time Machine Setup enthält TM_PLIST="/Library/Preferences/com.apple.TimeMachine.plist" # Überprüfe, ob die Plist-Datei existiert if [ ! -f "$TM_PLIST" ]; then echo "Die Datei $TM_PLIST existiert nicht." exit 1 fi # Verwende defaults read und perl, um das Datum des letzten Backups zu finden last_backup_date=$(defaults read "$TM_PLIST" Destinations | \\ perl -0777 -ne 'print "$1\\n" if /SnapshotDates\\s+=\\s+\\(\\s+(.*?)\\s+\\)/s') # Extrahiere das letzte Datum (das letzte Backup) last_successful_backup_date=$(echo "$last_backup_date" | tail -n 1 | tr -d '[:space:]' | sed 's/"//g') # Überprüfe, ob ein Datum vorhanden ist if [ -n "$last_successful_backup_date" ]; then # Schneide die letzten 5 Stellen ab last_successful_backup_date=$(echo "$last_successful_backup_date" | cut -c 1-$((${#last_successful_backup_date}-5))) # Ausgabe des letzten erfolgreichen Backup-Datums echo "<result>$last_successful_backup_date</result>" else echo "<result>1907.01.01 01.00.00</result>" fi
Get backup destination
#!/bin/bash # Plist-Datei, die das Time Machine Setup enthält TM_PLIST="/Library/Preferences/com.apple.TimeMachine.plist" # Überprüfe, ob die Plist-Datei existiert if [ ! -f "$TM_PLIST" ]; then echo "Die Datei $TM_PLIST existiert nicht." exit 1 fi # Verwende PlistBuddy, um das letzte Time Machine Backup-Ziel zu erhalten last_backup_target=$(/usr/libexec/PlistBuddy -c "Print Destinations:0:LastKnownVolumeName" "$TM_PLIST") # Ausgabe des letzten Backup-Ziels if [ -z "${VAR}" ]; then echo "<result>$last_backup_target</result>" else echo "<result>Unknown</result>" fi
Franky779
  • March 20, 2024
Sorry there was an error in return last backup date.
#!/bin/bash # Plist-Datei, die das Time Machine Setup enthält TM_PLIST="/Library/Preferences/com.apple.TimeMachine.plist" # Überprüfe, ob die Plist-Datei existiert if [ ! -f "$TM_PLIST" ]; then echo "Die Datei $TM_PLIST existiert nicht." exit 1 fi # Verwende defaults read und perl, um das Datum des letzten Backups zu finden last_backup_date=$(defaults read "$TM_PLIST" Destinations | \\ perl -0777 -ne 'print "$1\\n" if /SnapshotDates\\s+=\\s+\\(\\s+(.*?)\\s+\\)/s') # Extrahiere das letzte Datum (das letzte Backup) last_successful_backup_date=$(echo "$last_backup_date" | tail -n 1 | tr -d '[:space:]' | sed 's/"//g') # Überprüfe, ob ein Datum vorhanden ist if [ -n "$last_successful_backup_date" ]; then # Extrahiere das Jahr, den Monat, den Tag, die Stunde, die Minute und die Sekunde year=$(echo "$last_successful_backup_date" | cut -c 1-4) month=$(echo "$last_successful_backup_date" | cut -c 6-7) day=$(echo "$last_successful_backup_date" | cut -c 9-10) hour=$(echo "$last_successful_backup_date" | cut -c 11-12) minute=$(echo "$last_successful_backup_date" | cut -c 14-15) second=$(echo "$last_successful_backup_date" | cut -c 17-18) # Formatieren des Datums im "YYYY.MM.DD hh:mm:ss" Format formatted_date="${year}.${month}.${day} ${hour}:${minute}:${second}" # Ausgabe des letzten erfolgreichen Backup-Datums echo "<result>$formatted_date</result>" else echo "<result>1907.01.01 01.00.00</result>" fi
