Cisco Secure Client 5.1.2.42 anyconnect_choices.xml
  • March 22, 2024
  • 255 views
Just had to rebuild the installer package for the Cisco Secure Client. Dumped the choices and attempted to deploy. The deployment would not install. Turns out the dump from installer of the choices xml file is malformed. I was able to put together a working xml from my 4.10 package. We are only installing the VPN module but all the others are there to enable. Here are the contents
<plist version="1.0">
<array>
<dict>
<key>attributeSetting</key>
<integer>1</integer>
<key>choiceAttribute</key>
<string>selected</string>
<key>choiceIdentifier</key>
<string>choice_vpn</string>
</dict>
<dict>
<integer>0</integer>
<string>choice_websecurity</string>
</dict>
<dict>
<string>choice_fireamp</string>
</dict>
<dict>
<string>choice_dart</string>
</dict>
<dict>
<string>choice_posture</string>
</dict>
<dict>
<string>choice_iseposture</string>
</dict>
<dict>
<string>choice_secure_umbrella</string>
</dict>
<dict>
<string>choice_zta</string>
</dict>
<dict>
<string>choice_duo</string>
</dict>
<dict>
<string>choice_thousandeyes</string>
</dict>
</array>
</plist>
1 reply
danlaw777
  • March 25, 2024
see the post in this thread by Obi-k. https://community.jamf.com/t5/jamf-nation/cisco-secure-client-5-1-0-136-system-certificate-trust-settings/m-p/312488#M3140
using the pkg utility worked much better and my results were fantastic
@mvu was a GENIUS in doing it this way
