JAMF computer name change won't stick
  • April 3, 2024
  • 12 replies
  • 278 views
I am trying to change a computer's name by editing it in the computer's Jamf Pro inventory > General page. I have a policy to change all of my managed computers' names to match the names set in Jamf, so theoretically this name change should be pushed out to the machine after I updated it in Jamf. This is an iMac running MacOS14.4.1. But when I change the name on this machine and save it, the page reverts back to the default "iMac" name. I've done this hundreds of times and have never had an issue getting a name change to stick in the Jamf Pro inventory. Has anyone else seen this issue?
Best answer by mojo21221
I believe there is a bug in the jss that jamf currently working on cant think of the PI at the moment. But file a ticket with support and let them know you are suffering.
AJPinto
  • April 3, 2024
On macOS the hostname is set in 3 areas. I have never had any luck using the computers record to actually set a hostname, so I use a script with a policy to run on devices that the hostname does not meet our standards. Below is the script I use, granted we just set the hostname to the serial number. You could adjust the variable to call a value from Jamf to meet your needs if this is helpful.
#!/usr/bin/env bash #*============================================================================= #* Script Name: Configuration: Set Hostname 2301 #* Created: [01.12.2023] #* Author: Anthony Pinto #*============================================================================= #* Purpose: Requests input and renames computer based on Naming Convention 2301 #*============================================================================= #*============================================================================= #* REVISION HISTORY #*============================================================================= #* Date: [01.12.2023] #* Author: Anthony Pinto #* Issue: First version of this script #* Solution: N/A #*============================================================================= #*============================================================================= #* GLOBAL VARIABLES #*============================================================================= DIV1='echo ####################################################################' DIV2='echo --------------------------------------------------------------------' DIV3='echo ....................................................................' ActiveUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }' | tr "[a-z]" "[A-Z]"` ActiveUserRealName=`dscl . -read /Users/$ActiveUser | grep RealName: | cut -c11-` if [[ -z $ActiveUserRealName ]]; then ActiveUserRealName=`dscl . -read /Users/$ActiveUser | awk '/^RealName:/,/^RecordName:/' | sed -n 2p | cut -c 2-` fi computerName=$(scutil --get ComputerName) hostName=$(scutil --get HostName) localHost=$(scutil --get LocalHostName) serialNumber=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}') serialNumberII=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}' | tr -d '"') #*============================================================================= #* FUNCTIONS #*============================================================================= userInfo () { echo; $DIV1 echo "User Information:" if [[ "$ActiveUserRealName" == "$ActiveUser" ]]; then echo "$ActiveUserRealName (Local Admin)" else echo "$ActiveUserRealName ($ActiveUser)" fi $DIV1 } #*============================================================================= #* SCRIPT BODY #*============================================================================= userInfo ## Check & Update Computer Name if [ "$computerName" == "$serialNumber" ] then echo "Computer name matches serial number, $serialNumber" else echo "Current Computer Name: $computerName" echo "Computer Name does not meet standards" echo "Changing Computer Name to match Serial Number" scutil --set ComputerName "$serialNumber" fi; $DIV2 ## Check & Update Host Name if [ "$hostName" == "$serialNumber" ] then echo "Host Name matches serial number, $serialNumber" else echo "Current Host Name: $hostName" echo "Host Name does not meet standards" echo "Changing Host Name to match Serial Number" scutil --set HostName "$serialNumber" fi; $DIV2 ## Check & Update Local Host if [ "$localHost" == "$serialNumber" ] then echo "Local Host matches serial number, $serialNumber" else echo "Current Local Host: $localHost" echo "Local Host does not meet standards" echo "Changing Local Host to match Serial Number" scutil --set LocalHostName "$serialNumber" fi; $DIV2 ## Final Check computerNameII=$(scutil --get ComputerName) hostNameII=$(scutil --get HostName) localHostII=$(scutil --get LocalHostName) echo "" echo "Serial number: $serialNumber" echo "Computer Name: $computerNameII" echo "Host Name: $hostNameII" echo "Local Host: $localHostII" if [[ "$computerNameII" == "$serialNumber" ]] && [[ "$hostNameII" == "$serialNumber" ]] && [[ "$localHostII" == "$serialNumber" ]] then echo "Computer Name satisfies naming standards" $DIV1; exit 0 else echo "Computer does not meet naming standards" echo "More troubleshooting will be necessary." $DIV1; exit 1 fi ## Perform final Recon to update computer name on Jamf sudo jamf recon #*============================================================================= #* END OF SCRIPT #*=============================================================================
mojo21221
  • April 3, 2024
Check the iMac topic ID and your Jamf Server topic ID. I would start there, if they don't match it then no change will be pushed to the endpoint.
Jamf support suggested renaming them using MUT or scripting and pushing policy, unfortunately they keep getting renamed back to it's original default name.
  • April 8, 2024
I filed a ticket and this solved it, thanks!
DavidSpribe
  • April 11, 2024
This problem is still not solved. Only the people with Group Access (Admin) privileges have the problem with renaming computers in the inventory list. Full Access admins do not have such problem
  • April 30, 2024
Hey Just wanted to add another person to this list, I have also already created a ticket for this.
It also affects certain ext attributes in the general section. We can't add  data in any ext attribute that has text entry as an option. (we use one for quick notes for example)
Workaround is to move the attribute to a different inventory section instead of general, but obviously we can still not rename the computers.
I am having the same issue. Manually changed a couple of names in Jamf, but with no result. I would love to see this fixed.
  • September 25, 2024
Currently experiencing this issue when trying to rename an Apple TV.
rcole
  • October 10, 2024
Same issue. Reverts back to basic name even after name is changed in JSS. Does not appear to be a part of any history either.
  • June 5, 2025
I also have this problem. Getting really annoying.
  • June 5, 2025
I'm still having it too.
idrake
  • October 16, 2025
Also still having this issue!
