How do I obtain a computer's Jamf Pro computer ID using API?
  • April 9, 2024
  • 6 replies
  • 590 views
howie_isaacks
Forum|alt.badge.img+23
I'm working creating a script that performs several functions. One of the functions requires me to obtain the computer's Jamf Pro ID. I'm trying to figure out how to do this using the new API. I thought if I have a variable for the computer's serial number I could use that to query for the Jamf Pro ID. Is this possible?
Best answer by howie_isaacks
Thanks for the suggestions. On another Jamf Nation thread, I found this command:
deviceID=$(curl -s -H "Accept: text/xml" -H "Authorization: Bearer ${token}" ${jamfProURL}/JSSResource/computers/serialnumber/"$serialNumber" | xmllint --xpath '/computer/general/id/text()' -)
I tried it and it did return my computer ID. I am very new to the API. It's the only major feature of Jamf Pro I have not had a chance to dive into. Comparing the URL above to other API URLs I have used this one appears to be the "classic" API. I can't seem to do this with the newer API. Either I'm still too inexperienced with the API to figure it out or it's not possible in the new API? The ultimate goal is to assign computers to a specific site after enrollment. We use LDAP to fill in information into User and Location which would make the computer fall into a smart group that can be scoped to a policy to assign the computer to one of our sites. This is necessary because we have admins who can only see computers in the sites that they have access to. Using the API appears to be the only way I can automate this. We could assign computers to PreStages that will auto assign the computers to specific sites but this won't work for us since we don't always know where computers are going to be deployed and it would be a nightmare trying to manage that. Here's the script that I created from all that I have learned so far. The final result is that it provides the Jamf Pro ID for my computer.
#!/bin/zsh serialNumber=$(system_profiler SPHardwareDataType | grep Serial | /usr/bin/awk '{ print $4 }') # API login jamfProURL="https://YourServer.jamfcloud.com" username="apiUser" password="SuperDuperSecretPassword" # request auth token authToken=$( /usr/bin/curl \\ --request POST \\ --silent \\ --url "$jamfProURL/api/v1/auth/token" \\ --user "$username:$password" ) # parse auth token token=$( /usr/bin/plutil \\ -extract token raw - <<< "$authToken" ) # determine Jamf Pro device id deviceID=$(curl -s -H "Accept: text/xml" -H "Authorization: Bearer ${token}" ${jamfProURL}/JSSResource/computers/serialnumber/"$serialNumber" | xmllint --xpath '/computer/general/id/text()' -) echo "$deviceID"
  • April 9, 2024
In the Jamf Pro API it mentions there is a "Return all sections of a computer" method which you can use via the following API endpoint. Documentation for the specific API endpoint is here:
https://developer.jamf.com/jamf-pro/reference/get_v1-computers-inventory-detail-id
The API endpoint does a lookup using the Mac computer ID instead of serial number however...
  • April 9, 2024
Alternatively you could get inventory data for all Macs and then search for the specific Mac serial number, and then get the management ID:
sdagley
  • April 10, 2024
If you look at what running "jamf recon" sends to stdout the last line contains the Jamf Pro ID for the computer.
howie_isaacks
  • April 10, 2024
howie_isaacks
  • April 10, 2024
I got my script finished today. The goal was to have a script that could assign Macs to a site. Since I got some ideas from this thread, I posted my entire script there.
https://community.jamf.com/t5/jamf-pro/api-assign-computers-from-group-x-to-site-y/m-p/187368
With no API used
sudo jamf recon | grep computer_id | cut -f2 -d '>' | cut -f1 -d'<'
