Unable to install application in iPad without loging in apple id
  • May 7, 2024
  • 15 replies
  • 34 views
We have a requirement for a Kisk devices on our reception for a Power Apps built for visitors.
I am utilising a single app mode to deploy this.
However the application is not installing without entering the apple id.
Best answer by RaxiaDK
Power Apps on the App Store (apple.com)
its a free app; do I still need to get VPP ? as even on app deployment in jamf pro that option is greyed out
You need a license, a VPP or a user licenese
if it free, its gray out
You need to map the license, to get a device license
RaxiaDK
  • May 7, 2024
What app is it, as you sould could push it with VPP https://support.apple.com/en-us/102073
  • May 7, 2024
RaxiaDK
  • May 7, 2024
  • May 7, 2024
it is a free application Power Apps on the App Store (apple.com) that I am trying to deploy using "Mobile Device Apps". The VPP codes tab in the app says content not available to assign to mobile device. May be because it is a free application.
RaxiaDK
  • May 7, 2024
Do you have a Apple Buiness manager or a Apple school manager
RaxiaDK
  • May 7, 2024
you need to "buy" the license
  • May 7, 2024
 yes I do :)
RaxiaDK
  • May 7, 2024
you then have a licensed edition
RaxiaDK
  • May 7, 2024
  • May 7, 2024
if its not too dumb question; can you assist me with an article for next steps ( I am more from Windows world and picking  things up on mac)
RaxiaDK
  • May 7, 2024
 yes I do :)
after "buy" the license, you need to control if you have the license here
RaxiaDK
  • May 7, 2024
What do you need now?
If you want to chat I am @AndersDamsgaard on slack  / https://www.macadmins.org/
  • May 7, 2024
Thanks a ton; I think this is what I have to do next
Syncing Apps from Apple Business Manager to Jamf Pro/Now
Syncing apps from Apple Business Manager (ABM) to Volume Purchasing in Jamf Pro/Now:
Part 1: Download Server Token from Apple Business Manager
Log in to Apple Business Manager: Go to https://www.apple.com/business/.
Access Preferences: Click your account name in the bottom left corner and select "Preferences."
Download Server Token:Click on "Payments and Billing."
Under the "Apps and Books" tab, click "Download" next to the appropriate server location (ensure it matches your Jamf server region).
The token downloads to your computer's Downloads folder (usually named something like "com.apple.vpp.itunescontent.serverlocationtoken").
Part 2: Configure Volume Purchasing in Jamf Pro/Now
Open Jamf Pro/Now: Launch the Jamf Pro/Now application.
Go to Settings: Click on "Settings" in the sidebar menu.
Access Volume Purchasing:In Jamf Pro: Under the "Global" section, click "Volume Purchasing."
In Jamf Now: Click on "Volume Purchasing" directly.
Add a New Location (Jamf Pro only):If this is your first time setting up Volume Purchasing, click "New."
Enter a descriptive name for the location (e.g., "ABM Apps"). This name is for reference only.
Upload Downloaded Token:Click on a location (New one in Jamf Pro or the existing one).
Click "Edit" (Jamf Pro) or the pencil icon (Jamf Now).
Click "Renew Server Token" (Jamf Pro) or "Upload Server Token" (Jamf Now).
Browse and select the server token downloaded from ABM in step 1.
Save Changes: Click "Save" (Jamf Pro) or "Save Changes" (Jamf Now) to complete the configuration.
Additional Notes:
The server token expires after a year. Repeat steps 1-3 in ABM to download a new token when needed.
Jamf will automatically sync apps from ABM to Volume Purchasing based on your configuration.
  • May 7, 2024
unable to join workspace on slack; may I ask you for an invite on [email deleted by moderator].
RaxiaDK
  • May 7, 2024
I have invited you now, please delete or edit your email
