We're transitioning over to a new printing system and I need to remove printers on all macOS machines. The printers are all named by site, for example Miami HP 504, Dallas HP 653 etc.
What's a good way to delete the printers in bulk by using the site names? I have a script that works for one site at a time. I don't want to just remove all printers as there may be personal printers installed.
bash arrays would be the answer maybe?
https://linuxhandbook.com/bash-arrays/
This may work. I was playing around with using a for loop. It just deleted the printers from my Mac. You would add at list of your printer names to the "printers" variable.
#!/bin/zsh
printers=("Printer1" "Printer2")
for printer in ${printers[@]}; do
/usr/sbin/lpadmin -x "$printer"
done
#!/bin/zsh
done
yup.. that works and if there are 'a lot' you could always pull in the list from a CSV
I'm curious how you would do this from a CSV. I think I know how and when I have time I will try it later.
foo=$(cat path/to/text.csv)
I ended up doing:
lpstat -a | cut -d " " -f1 | grep "Miami_" | while read MIAMI
do
echo "-- Miami printers detected attempting to delete:" $MIAMI
lpadmin -x $MIAMI
sleep 1
done
and just repeat for each site . . .
You could potentially make a loop around what you've done there Chris and then use a Here Doc.  Here's an example script for Here Doc's
# here_doc_test.bash
SITES=$(cat <<EOF
Miami_
Orlando_
Austin_
Phoenix_
EOF
echo $SITES
for i in $SITES
do
echo $i
done
