Installomator Block App Launch During Update
  • May 10, 2024
  • 34 views
_aDiedericks
Hi there, does anyone know if Installomator has a "block app from launching" option or if there is a way to script a block app launch until an update to completed. Currently in our environment we have Installomator handling patch management with SwiftDialog, users still decide to launch whatever app is being updated while the SwiftDialog clearly shows it is updating 😑
Ideally would like to be able to block the app from launching while updating or to have a separate script that will block the app from launching until the update is completed.
1 reply
_aDiedericks
  • May 10, 2024
If it's possible to hide app before the update script runs and then unhide it afterwards that would also work
