Veeam Agent for Mac via JAMF
  • May 22, 2024
  • 40 views
Hello!
I am currently trying to install Veeam via JAMF and I am using the instructions from this post:
https://community.jamf.com/t5/jamf-pro/deploying-veeam-agent-for-mac-using-jamf/m-p/246434#M230724
The agent is installed & gets full disk access but does not import the configuration for the backup job. Is there an updated install instruction?
1 reply
AJPinto
  • May 31, 2024
If Veeam still doesn't provide documentation and directs you to your MDM, don't expect it to work. The vendor may have changed something, requiring updates to the old instructions. Your best bet is to contact Veeam for help, but it seems unlikely you'll get the support you need.
