Script to uninstall Cisco Secure Client (5.1.1.42)
  • March 22, 2024
  • 79 views
I'm testing a script, but looking for a better suggestion that runs silently without any user invention. Running the uninstaller app isn't ideal.
# Path to the uninstallation apps
UNINSTALL_APP="/Applications/Cisco/Uninstall Cisco Secure Client.app"
DART_UNINSTALL_APP="/Applications/Cisco/Uninstall Cisco Secure Client - DART.app"
# Check if the uninstall app exists and execute it with sudo
if [ -e "$UNINSTALL_APP" ]; then
echo "Uninstalling Cisco Secure Client..."
sudo open "$UNINSTALL_APP"
echo "Cisco Secure Client uninstallation app not found."
# Check if the DART uninstall app exists and execute it with sudo
if [ -e "$DART_UNINSTALL_APP" ]; then
echo "Uninstalling Cisco Secure Client - DART..."
sudo open "$DART_UNINSTALL_APP"
echo "Cisco Secure Client - DART uninstallation app not found."
1 reply
mvu
Forum|alt.badge.img+21
  • March 22, 2024
/opt/cisco/secureclient/bin/amp_uninstall.sh
/opt/cisco/secureclient/bin/dart_uninstall.sh
/opt/cisco/secureclient/bin/iseposture_uninstall.sh
/opt/cisco/secureclient/NVM/bin/nvm_uninstall.sh
/opt/cisco/secureclient/bin/umbrella_uninstall.sh
/opt/cisco/secureclient/bin/zta_uninstall.sh
### Uninstall Duo Desktop and Duo Device Health
/Applications/Duo\\ Desktop.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
/Applications/Duo\\ Device\\ Health.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
### Uninstall ThousandEyes Agent
/Applications/Cisco/Cisco\\ Secure\\ Client\\ -\\ ThousandEyes\\ Endpoint\\ Agent.app/Contents/Resources/uninstall.sh
