Hi! I am guessing I can use the Jamf Pro API for this on a wrapper script cronned on GitHub Actions.
Could you please provide an example of using the API to re-apply en existing profile to the current laptops it is scoped?
IMPORTANT: If you wonder why I want to do this: It is because users need to disable Wandera for accessing certain wifi hotspots and sometimes they forget to re-enable it. Therefore, re-applying the profile to all the users will automatically re-enable Wandera for them.
I was thinking on something like this:
curl -X PUT \\ https://split.jamfcloud.com/JSSResource/mobiledeviceconfigurationprofiles/id/39 \\ --header 'authorization: Basic MY_CREDENTIALS' \\ --header 'content-type: application/xml' \\ --data '<configuration_profile> <general> <redeploy_on_update>All</redeploy_on_update> </general> <scope> <all_computers>true</all_computers> </scope> </configuration_profile>'
However, I don't know if this will automatically trigger the re-deployment of the profile since it is already scoped to "All Computers". Could somebody confirm?
