You seem to be straddled across a fence. The function of NoMad is to not need to Domain bind, and you are using both.
- NoMad cannot automatically sync or update passwords. When a user changes their password on another device, they will still need to log in to the Mac with the old password. NoMad should pickup that it has the wrong password and prompt to log in. Once the user logs in to NoMad again it should sync the LDAP password with macOS and update everything.
- Domain Binding should tell macOS to reach out to your AD instance from the log in window and macOS "should" use the current AD PW to authenticate the user. Note with AD binding, Apple stopped developing this work flow for macOS some 10 years ago. So there are A LOT of issues with macOS in a Domain environment, especially if you change your password on another device and expect the Mac to respect AD.
- If these Macs are always expected to be on a network you may not want to create mobile accounts at login.
- Updating the FileVault password will not work with Domain Binding alone, NoMad must do this or it needs to be done manually.
We moved off of NoMad last year to JAMF Connect. This is the last version of the configuration profile we had used. We were domain bound and using NoMad for password changes as we restricted System Pref > Users. We had consistent issues if a user changed a password on another device also, its just the nature of the beast.
<plist version="1.0">
<dict>
<key>ADDomain</key>
<string>something.here.com</string>
<key>CleanCerts</key>
<true/>
<key>ConfigureChrome</key>
<true/>
<key>DontShowWelcome</key>
<true/>
<key>GetHelpOptions</key>
<string>https://help</string>
<key>GetHelpType</key>
<string>URL</string>
<key>HideAbout</key>
<true/>
<key>HidePrefs</key>
<true/>
<key>HideSignOut</key>
<false/>
<key>LoginItem</key>
<false/>
<key>MenuHomeDirectory</key>
<string>H Drive</string>
<key>MenuRenewTickets</key>
<string>Refresh</string>
<key>RenewTickets</key>
<true/>
<key>SecondsToRenew</key>
<integer>7200</integer>
<key>ShowHome</key>
<true/>
<key>SignInWindowAlert</key>
<true/>
<key>SignInWindowOnLaunch</key>
<true/>
<key>UPCAlert</key>
<true/>
<key>UseKeychain</key>
<true/>
<key>UseKeychainPrompt</key>
<true/>
<key>Verbose</key>
<true/>
</dict>
</plist>
<dict>
<key>ADDomain</key>
<true/>
<true/>
<true/>
<true/>
<true/>
<false/>
<false/>
<true/>
<key>ShowHome</key>
<true/>
<true/>
<true/>
<key>UPCAlert</key>
<true/>
<true/>
<true/>
<key>Verbose</key>
<true/>
</dict>
</plist>
Thank you for your reply and explanation. I'm definitely going to look into moving to JAMF connect during summer, I just have to get through this semester and this password issue. I'm leaning in removing nomad all together and just leave the lab systems bound to get me through this semester with no more calls until I can spend the time to properly deploy Jamf connect.
