Jamf Cloud web session timeout change?
  • November 3, 2022
  • 13 replies
  • 308 views
pbenware1
Hey All,
Is it possible to change the timeout on a Jamf Cloud console session?
We're on Jamf Cloud 10.42 using SSO to login to the console, if that matters.
The main issue (among others), is that when performing a GSX lookup, the web session usually times out before the look up finishes.
We have ~1400 workstations which takes at least 10-15 minutes to update, but more often than not results in a session timeout.
I've tried creating a SMART group where there is no Warranty info for the device, but the only options are Warranty Expiration is before/after or within a certain # of days.
It does seem as though if I open a new JSS tab in the same browser window and work in there while the GSX lookup is ongoing in the other tab, that the GSX lookup session will not timeout.
I did check the SSO settings, but it only has a Token expiration time, which is not what I'm looking for.
Thanks for any thoughts.
Phil
Best answer by Fveja
Hi @pbenware1 I created https://github.com/fveja/JSSCaffeinate for this reason!  It works by keeping alive the web session.
Cheers,
Florin
  • November 3, 2022
Cheers,
Florin
pbenware1
  • November 4, 2022
Cheers,
Florin
Sweet.  TY, I will definitely give this a try.
  • November 4, 2022
Great!  Let me know how it works for you and what you think!
pbenware1
  • November 4, 2022
Worked for me.  Ran my GSX update with 0 timeouts.
But it does beg the question of why this can't be made longer or user configurable.
jamf-42
  • November 4, 2022
you can, if you move to dedicated instance..  $20k last time I looked.. 😱 (it does have some other 'stuff')
pbenware1
  • November 4, 2022
@jamf-42 Thanks for that.  I found the PDF for the Premium Cloud service.  Best guess is my org won't spring another $20K just to stop my complaining about timeouts, even with the other features.
jamf-42
  • November 4, 2022
yea.. tuff one.. "but it will save 10mins a day!!" 🤣  was simple to do when on prem.. it should at least be an option (like you know every other admin panel!)  at least we have a new design on the config page!
  • July 26, 2024
Cheers,
Florin
It's not working for me. Here's what I got when I try to run it:
./caffeinate.js: line 1: //: is a directory
./caffeinate.js: line 2: //: is a directory
./caffeinate.js: line 3: //: is a directory
./caffeinate.js: line 4: //: is a directory
./caffeinate.js: line 5: //: is a directory
./caffeinate.js: line 6: //: is a directory
./caffeinate.js: line 7: //: is a directory
./caffeinate.js: line 8: //: is a directory
./caffeinate.js: line 9: //: is a directory
./caffeinate.js: line 11: syntax error near unexpected token `'Started JSS Caffeinate. Running on ''
./caffeinate.js: line 11: `console.log('Started JSS Caffeinate. Running on ' + location.href)'
Maybe I am doing something wrong. Any advice?
jamf-42
  • July 26, 2024
can't remember who made the JS.. but use Arc Browser.. setup a Boost and add this JS.. it works..
EDIT: oh it's the same code! Use Arc boost.. 😎
// ==UserScript== // JSS Caffeinate // @version 0.3 // @description Simulates mousedown events every few minutes, to activate keepalive call of JSS // @match https://<yourJssUrlWithoutPort>/* // @updateURL https://github.com/fveja/JSSCaffeinate/raw/main/JSS%20Caffeinate.js // @noframes // Florin Veja 2022 // ==/UserScript== console.log('Started JSS Caffeinate. Running on ' + location.href) // delay, in milliseconds, before we send mousedown event (120000 milliseconds = 2 min) const delay = 120000 var last = Date.now() const name = "JSS Caffeinate" // set to true for debug console output const jssCaffeinateDebug = false // function to send us back to the const login = () => { debug("logging in") location = location.origin } const debug = (m) => { typeof jssCaffeinateDebug == 'boolean' && jssCaffeinateDebug && console.log(name + " debug: " + m) } const authExpiration = () => { return JSON.parse(localStorage.authToken).expires - Date.now() } const getDelay = (max) => { const min = 10000 return Math.random() * (max - min) + min } // if we are on the logout page, log back in // randomize to not create a race if (location.pathname == '/logout.html') { setTimeout(login(), getDelay(10000)) } const café = setInterval(() => { var start = Date.now() const mousedown = new Event('mousedown') debug('JSS Caffeinate keepalive ' + start) document.dispatchEvent(mousedown) debug("authToken expires in " + authExpiration()) debug(last + " - " + start + "=" + (start - last)) last = start if (authExpiration() < 1) { login() } }, delay);
  • July 27, 2024
What browser and what user-script plugin are you using?
coachdnadel
  • May 21, 2025
Is this still the only solution? I cannot find $20,000 to fix my technicians' frustrations.
  • September 5, 2025
Unfortunately, yes. I just spoke with Jamf’s support (after losing work for the 1,000th time 😡) and they confirmed that...by sending the PDF for Premium Cloud 🙄. It seems only a little bit ridiculous to require $20K to include this basic feature.
pete_c
  • September 8, 2025
Here’s a pure AppleScript version.
# 1.0.1 @pete_c 241216
# sh ./reload-jss.sh &
# automatically reload the JSS w/o any browser extensions
# note that you might get a TCC prompt on first run
# TO-DO: read jss_url from .plist, pass into the osascript
# kill any previous processes
if ps -ax | grep sh | awk '/reload-site/ { print $1 } ' >/dev/null; then
pkill -f "reload-site.sh"
# trailing slash actually might not be required anymore? but port is if you're on prem
while true
do
osascript -e 'tell application "Google Chrome" to repeat with W in windows
reload (every tab in W whose URL is "https://your.jss.tld/") # trailing slash is required
end repeat'
sleep 500
done
