Contracting Information about Mysql version required by JSS
  • April 4, 2022
  • 17 views
Looking at the release notes is get the following information about the mysql version required by a given JSS version:
JSS Min Rec
10.34 5.7.13 5.7.13 / 8.0 *
10.35 5.7.13 5.7.13 / 8.0
10.36 5.7.36 5.7.36 / 8.0.27
10.37 5.7.36 5.7.36 / 8.0.28
* Min was 5.7.8 initially, changed on Dec 16th 2021 to 5.7.13
According to this I must update mysql to 5.7.37 before updating to JSS 10.36 or 10.37.
But according to https://docs.jamf.com/technical-articles/Incremental_Upgrade_Scenarios_for_Jamf_Pro_10-0-0_or_Later.html there is no need to update mysql if I already use 5.7.13.
So which information is correct? Do I have to update mysql to 5.7.36, or can I continue with 5.7.13 or higher?
When we urgent need to update the JSS due to some vulnerability like CVE-2022-22965 it would be good to have reliable information about the System Requirements and potential incremental update steps.
1 reply
  • April 4, 2022
@mschroder , my suggestion would be that you go by the System Requirements on the version Release Notes that you are planning on upgrading to.
