Nudge help - Json
  • April 8, 2022
  • 53 views
So I have setup Nudge with Jamf and using the JSON shema, which is easy to setup settings etc with the pre-defined settings.
But when it comes to editing the text in the json, the changes I make in the json schema is not listed in the GUI on any device. I have tried to edit all fields possible in the "updateElements" section, but no changes takes effect.
Any one succeeded with that ?
So it just stays the same default view all the time
  • April 8, 2022
Hey there @Captainamerica , over in the MacAdmins group in Slack, there is a Nudge channel where loads and loads of information is discussed.  I suggest trying to head over there if you can and reading through the problems other folks have had and how they've resolved them.
I also use Nudge and love it.  I created my own little how-to document and after reviewing some of the presentations on it available out there on the webs, I kept this as a reference so I'd know what element to edit for whatever I was attempting to say:
Does this help at all?
  • April 8, 2022
Hey there!
Make sure you are setting your language to "en" or else you will not see changes. Check out the wiki and the first line here: https://github.com/macadmins/nudge/wiki/Common-Issues
Example:
Hope that helps! Also, +1 to the suggestion for joining the slack! Lots of good info over there!
