Script Error - JAMF tmp command not found
  • March 7, 2022
  • 5 replies
  • 92 views
Please I need some assistance, I have had this issue for a while now.
I have 2 policies running a script
the 1st policy modifies a plist via the script and 2nd policy downloads and installs a package using curl and they both have the same issue.
This is the error I'm getting
Error from policy 1
Script result: /Library/Application Support/JAMF/tmp/New Follow Print Plist: line 4: -u: command not found
/Library/Application Support/JAMF/tmp/New Follow Print Plist: line 7: /Users/patsnous/Library/Application\\ Support/hcpclient/hcpclient.plist: No such file or directory 2022-03-07 08:37:41.105 defaults[61211:847827] Domain /Users/user/Library/Application\\ Support/hcpclient/hcpclient.plist does not exist
Error from policy 2
curl: (23) Failed writing body (0 != 1388) tar: Error opening archive: Failed to open 'elastic-agent-7.16.3-darwin-x86_64.tar.gz' /Library/Application Support/JAMF/tmp/Elastic Agent: line 11: cd: elastic-agent-7.16.3-darwin-x86_64: No such file or directory /Library/Application Support/JAMF/tmp/Elastic Agent: line 13: ./elastic-agent: No such file or directory /Library/Application Support/JAMF/tmp/Elastic Agent: line 15: elastic-agent: command not found
DBrowning
  • March 7, 2022
It would help to see the scripts that are running to better understand the error messages.
  • March 7, 2022
The scripts I'm running @DBrowning
Policy 1
logged_in_user=$(/usr/sbin/scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ {print $3}')
logged_in_uid=$(id -u "$logged_in_user")
result=$(/bin/launchctl asuser "$logged_in_uid" sudo -iu "$logged_in_user")
cat << EOF > "/Users/$logged_in_user/Library/Application\\ Support/hcpclient/hcpclient.plist"
<plist version="1.0">
<dict>
<key>account_domain</key>
<string>xxx.xxx.eophcp.com</string>
<key>allow_configuration</key>
<true/>
<key>allow_remember_login</key>
<true/>
<key>auth_type</key>
<integer>0</integer>
<key>delete_printers_on_logout</key>
<false/>
<key>direct_offline_print</key>
<false/>
<key>install_id</key>
<string>xxxxxxxxxxxxxxxxxxx</string>
<key>prompt_type</key>
<key>ps_to_pdf</key>
<false/>
<key>remember_login</key>
<false/>
<key>server_address</key>
<string>xxx.xxxxx.eophcp.com</string>
<key>storage_type</key>
<integer>1</integer>
<key>sync_interval</key>
<integer>60</integer>
</dict>
</plist>
EOF
defaults read "/Users/$logged_in_user/Library/Application\\ Support/hcpclient/hcpclient.plist"
Policy 2
curl -L -O https://xxx.elastic.xxx/downloads/xxx/elastic-agent/elastic-agent-7.16.3-darwin-x86_64.tar.gz
tar -xzvf elastic-agent-7.16.3-darwin-x86_64.tar.gz
cd elastic-agent-7.16.3-darwin-x86_64
./elastic-agent install --force --url=https://xxxxxxxxxxxx.fleet.eu-west-2.aws.cloud.es.io:443 --enrollment-token=XXXXXXXXXX==
elastic-agent status
DBrowning
  • March 7, 2022
@IamZeus For the first one, it doesn't look like you call $result anywhere so I would just delete the line defining result (line 4) and I would remove the double quotes around the file path on line 7.  If you are going to keep the quotes, then you will have to remove the \\ after Application. Same thing with the last line defaults read.....
#!/bin/bash logged_in_user=$(/usr/sbin/scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ {print $3}') cat << EOF > /Users/$logged_in_user/Library/Application\\ Support/hcpclient/hcpclient.plist <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>account_domain</key> <string>xxx.xxx.eophcp.com</string> <key>allow_configuration</key> <true/> <key>allow_remember_login</key> <true/> <key>auth_type</key> <integer>0</integer> <key>delete_printers_on_logout</key> <false/> <key>direct_offline_print</key> <false/> <key>install_id</key> <string>xxxxxxxxxxxxxxxxxxx</string> <key>prompt_type</key> <integer>0</integer> <key>ps_to_pdf</key> <false/> <key>remember_login</key> <false/> <key>server_address</key> <string>xxx.xxxxx.eophcp.com</string> <key>storage_type</key> <integer>1</integer> <key>sync_interval</key> <integer>60</integer> </dict> </plist> EOF defaults read /Users/$logged_in_user/Library/Application\\ Support/hcpclient/hcpclient.plist
For the second one, I would write the file to the /tmp directory using -o and when using the cd command use the full path to the directory.  Also with calling the ./elastic command, use the full path as well.
#!/bin/bash curl -L https://xxx.elastic.xxx/downloads/xxx/elastic-agent/elastic-agent-7.16.3-darwin-x86_64.tar.gz -o /private/tmp/elastic-agent-7.16.3-darwin-x86_64.tar.gz tar -xzvf /private/tmp/elastic-agent-7.16.3-darwin-x86_64.tar.gz cd /private/tmp/elastic-agent-7.16.3-darwin-x86_64 /private/tmp/elastic-agent-7.16.3-darwin-x86_64/elastic-agent install --force --url=https://xxxxxxxxxxxx.fleet.eu-west-2.aws.cloud.es.io:443 --enrollment-token=XXXXXXXXXX== elastic-agent status
Give those a shot.
  • March 7, 2022
Hi @DBrowning , thank you for your help, plist script appears to work now.
Im getting this new error for the elastic agent script, unable to create directory, could it be a permission issue?
x elastic-agent-7.16.3-darwin-x86_64/: Can't create 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/elastic-agent: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/elastic-agent.reference.yml: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/elastic-agent.yml: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/README.md: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/NOTICE.txt: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/.build_hash.txt: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/LICENSE.txt: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/.elastic-agent.active.commit: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/elastic-agent: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/filebeat-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/fleet-server-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/filebeat-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/apm-server-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/fleet-server-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/osquerybeat-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/endpoint-security-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/osquerybeat-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/metricbeat-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/apm-server-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/heartbeat-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/fleet-server-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/heartbeat-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/metricbeat-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/apm-server-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/filebeat-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/osquerybeat-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/endpoint-security-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/heartbeat-7.16.3-darwin-x86_64.tar.gz.asc: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/endpoint-security-7.16.3-darwin-x86_64.tar.gz.sha512: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' x elastic-agent-7.16.3-darwin-x86_64/data/elastic-agent-d420cc/downloads/metricbeat-7.16.3-darwin-x86_64.tar.gz: Failed to create dir 'elastic-agent-7.16.3-darwin-x86_64' tar: Error exit delayed from previous errors. /Library/Application Support/JAMF/tmp/Elastic Agent: line 7: cd: /private/tmp/elastic-agent-7.16.3-darwin-x86_64: No such file or directory /Library/Application Support/JAMF/tmp/Elastic Agent: line 9: /private/tmp/elastic-agent: No such file or directory /Library/Application Support/JAMF/tmp/Elastic Agent: line 11: elastic-agent: command not found
MacJunior
  • October 27, 2022
@IamZeus did it work for you? i'm having the same issue !
