App PKG Installation Policy not working as intended
  • June 12, 2024
  • 5 replies
  • 103 views
Hi all,
I'm running in an issue concerning the installation of the OpenVPN app.
Basically I've deployed the after converting the .app into a .pkg via Composer, and the app works just fine untill our users need to connect via profile. If the user tries to connect to the VPN they are greeted with an error.
My issue is that, if I try to download the application using the original .dmg file (but that needs an admin login, that our users don't have) and run OpenVPN afterwards no error occurs and both the profile and the app work just fine 100% of the time.
I think this leaves me with 2 options: either let our users download and install OpenVPN via .dmg but without any need for an admin password or I need to push to our users every file that the .dmg install on the computer and not just the .app.
I'd really like to go for the first option since it could be useful in plenty other situations but sadly I don't know how to do neither of them.
Thank you for the help!
Best answer by jamf-42
Yup that's the one!
The DMG has both of the option inside but I'd need only di Silicon option since we have no Intel Mac deployed. The pkg in composer was my understanding of how to deploy an app that is neither in the app store nor in the jamf catalogue and it worked just fine for every other app that I need to deploy this way.
I'm new to Jamf and all this jazz so it could be that I made some basic mistakes and the solution could be pretty easy.
Upload the Arm pkg to jamf, add to policy, test, when your happy deploy.
composer is for when you don’t have a pkg or what to do something more bespoke with preinstall / post install scripts and more
jamf-42
  • June 12, 2024
The DMG has the app packaged for ARM and Intel? Why do you need to pkg in composer? (OpenVPN Connect 3_4_9) ?
client-connect-vpn-for-mac-os
  • June 13, 2024
Yup that's the one!
jamf-42
  • June 13, 2024
Yup that's the one!
  • June 13, 2024
It worked, thank you. Didn't think about just copy and pasting the pkg inside the dmg!
  • March 17, 2025
Do you have a way to configure the connection instead of the user? Because I would like to do it automatically, so that the user only clicks connect and enters their username and password, and does not have to manually add the configuration file.
